Error by building a BSP on Ubuntu 18.04
Gedare Bloom
gedare at rtems.org
Wed Mar 10 23:18:14 UTC 2021
Hi Olga,
On Wed, Mar 10, 2021 at 1:35 PM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
> Hi! I'm following this tutorial https://docs.rtems.org/branches/master/user/installation/kernel.html.
> After successfully building a tool chain for the SPARC architecture in step 5.1.1. I moved to the step 5.3.1. And then in step 5.3.4. I get an error:
> olga at olga-H270M-DS3H:~/development/rtems/kernel/erc32$ make -j 2
> Making all in sparc-rtems5/c
> make[1]: Entering directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
> Making all in .
> make[2]: Entering directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
> make[2]: Nothing to be done for 'all-am'.
> make[2]: Leaving directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
> Making all in erc32
> make[2]: Entering directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c/erc32'
> make[2]: *** No rule to make target 'all'. Stop.
> make[2]: Leaving directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c/erc32'
> Makefile:362: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
> Makefile:482: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
We would need a bit more. Is this on rtems5? Often, this kind of
failure indicates that configure failed, check your configure step.
In RTEMS6 we will be getting rid of configure, but for now there is
support for both in the RTEMS6 'master' branch.
> Did I miss something or am I doing something wrong? Many thanks in advance for your help!
> users mailing list
> users at rtems.org
