Error by building a BSP on Ubuntu 18.04
Olga Syrbachova
syrba4eva28 at gmail.com
Thu Mar 11 20:41:32 UTC 2021
It is RTEMS 5.1. I've checked the configure step. It seems to be fine. I
get this:
config.status: creating Makefile
target architecture: sparc.
available BSPs: erc32.
'make all' will build the following BSPs: erc32.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
And I still have the same error running make -j 2.
On Thu, 11 Mar 2021 at 00:18, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Olga,
> On Wed, Mar 10, 2021 at 1:35 PM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
> > Hi! I'm following this tutorial
> https://docs.rtems.org/branches/master/user/installation/kernel.html.
> > After successfully building a tool chain for the SPARC architecture in
> step 5.1.1. I moved to the step 5.3.1. And then in step 5.3.4. I get an
> error:
> > olga at olga-H270M-DS3H:~/development/rtems/kernel/erc32$ make -j 2
> > Making all in sparc-rtems5/c
> > make[1]: Entering directory
> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
> > Making all in .
> > make[2]: Entering directory
> > make[2]: Nothing to be done for 'all-am'.
> > make[2]: Leaving directory
> > Making all in erc32
> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c/erc32'
> > make[2]: *** No rule to make target 'all'. Stop.
> > Makefile:362: recipe for target 'all-recursive' failed
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory
> > Makefile:482: recipe for target 'all-recursive' failed
> > make: *** [all-recursive] Error 1
> We would need a bit more. Is this on rtems5? Often, this kind of
> failure indicates that configure failed, check your configure step.
> In RTEMS6 we will be getting rid of configure, but for now there is
> support for both in the RTEMS6 'master' branch.
> > Did I miss something or am I doing something wrong? Many thanks in
> advance for your help!
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/69f4982d/attachment-0001.html>
