Issues with configuring BSP with waf
Ida Delphine idadelm at gmail.com
Thu Mar 11 16:48:33 UTC 2021
Thank you for your response. I am not working on the rtems.git/master
branch. I'm not using it because earlier I tried downloading sources with
it but I got this error
error: shell macro failed:
/home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc
 -l : 2: error: no library (-l) provided
So I decided to use the other alternative(get the sources from releases)
Since I'm a GSoC applicant should I wait till the issue at the master
branch is resolved?
Cheers,
Ida.
On Thu, Mar 11, 2021 at 4:18 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 11, 2021 at 7:33 AM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello everyone,
> > Was following the quick build documentation and had issues around where
> I have to do a manual BSP build.  In the last step of configuring the BSP,
> I ran this command:
> > ./waf configure --prefix=$HOME/quick-start/rtems/5
> Are you working on rtems.git/master branch or /5 branch? Note that you
> need to be sure to use a consistent compiler toolchain based on the
> version of RTEMS that you use.
> In rtems/5 branch we don't have waf support integrated yet. The
> upgrade to waf is happening currently on the master branch, which will
> eventually become the RTEMS version 6 release.
> For GSoC students we expect development to happen on the development
> head and not a release, so please make sure that you have the
> toolchain built from rtems-source-builder.git/master and the rtems
> source tree from rtems.git/master.
> > It didn't produce the expected output. I instead got:
> > bash: ./waf: No such file or directory
> > As a result I downloaded it with the command:
> > curl https://waf.io/waf-2.0.19 > waf
> https://git.rtems.org/rtems/tree/waf
> Currently, the waf-based build of rtems only supports "in tree"
> builds, which means you need to run waf from within the rtems.git/
> root of your source. This is a limitation of the waf build.
> FWIW, waf build improvements could also fall under GSoC effort,
> although no one has written it up as a task yet. It would be mostly
> Python.
> > I ran  the last command to configure the BSP again but still did not get
> the expected  output. I got this rather:
> > Waf: Run from a folder containing a 'wscript' file (or try -h for the
> generic options)
> > Please how do I fix this? What am I missing?
> > I have tried looking for solutions but to no avail.
> Sometimes the solutions only exist inside other people's heads, so
> asking questions is encouraged.
> > Thanks,
> > Ida.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/76756c4c/attachment-0001.html>
