Issues with configuring BSP with waf
Thu Mar 11 15:18:02 UTC 2021
On Thu, Mar 11, 2021 at 7:33 AM Ida Delphine <idadelm at gmail.com> wrote:
> Hello everyone,
> Was following the quick build documentation and had issues around where I have to do a manual BSP build.  In the last step of configuring the BSP, I ran this command:
> ./waf configure --prefix=$HOME/quick-start/rtems/5
Are you working on rtems.git/master branch or /5 branch? Note that you
need to be sure to use a consistent compiler toolchain based on the
version of RTEMS that you use.
In rtems/5 branch we don't have waf support integrated yet. The
upgrade to waf is happening currently on the master branch, which will
eventually become the RTEMS version 6 release.
For GSoC students we expect development to happen on the development
head and not a release, so please make sure that you have the
toolchain built from rtems-source-builder.git/master and the rtems
source tree from rtems.git/master.
> It didn't produce the expected output. I instead got:
> bash: ./waf: No such file or directory
> As a result I downloaded it with the command:
> curl https://waf.io/waf-2.0.19 > waf
https://git.rtems.org/rtems/tree/waf
Currently, the waf-based build of rtems only supports "in tree"
builds, which means you need to run waf from within the rtems.git/
root of your source. This is a limitation of the waf build.
FWIW, waf build improvements could also fall under GSoC effort,
although no one has written it up as a task yet. It would be mostly
Python.
> I ran  the last command to configure the BSP again but still did not get the expected  output. I got this rather:
> Waf: Run from a folder containing a 'wscript' file (or try -h for the generic options)
> Please how do I fix this? What am I missing?
> I have tried looking for solutions but to no avail.
Sometimes the solutions only exist inside other people's heads, so
asking questions is encouraged.
> Thanks,
> Ida.
> users mailing list
> users at rtems.org
