Issues with configuring BSP with waf
Ida Delphine
idadelm at gmail.com
Thu Mar 11 17:03:30 UTC 2021
Okay. Thank you :)
On Thu, 11 Mar 2021, 5:57 pm Gedare Bloom, <gedare at rtems.org> wrote:
> On Thu, Mar 11, 2021 at 9:48 AM Ida Delphine <idadelm at gmail.com> wrote:
> > Thank you for your response. I am not working on the rtems.git/master
> branch. I'm not using it because earlier I tried downloading sources with
> it but I got this error
> > error: shell macro failed:
> /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc
> -l : 2: error: no library (-l) provided
> > So I decided to use the other alternative(get the sources from releases)
> > Since I'm a GSoC applicant should I wait till the issue at the master
> branch is resolved?
> Yes, that issue has been resolved so please try again. Hopefully,
> things work a bit better. We try not to break things, but unexpected
> problems come up from time to time, especially based on host OS
> dependencies.
> > Cheers,
> > Ida.
> > On Thu, Mar 11, 2021 at 4:18 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Thu, Mar 11, 2021 at 7:33 AM Ida Delphine <idadelm at gmail.com> wrote:
> >> > Hello everyone,
> >> > Was following the quick build documentation and had issues around
> where I have to do a manual BSP build. In the last step of configuring the
> BSP, I ran this command:
> >> > ./waf configure --prefix=$HOME/quick-start/rtems/5
> >> Are you working on rtems.git/master branch or /5 branch? Note that you
> >> need to be sure to use a consistent compiler toolchain based on the
> >> version of RTEMS that you use.
> >> In rtems/5 branch we don't have waf support integrated yet. The
> >> upgrade to waf is happening currently on the master branch, which will
> >> eventually become the RTEMS version 6 release.
> >> For GSoC students we expect development to happen on the development
> >> head and not a release, so please make sure that you have the
> >> toolchain built from rtems-source-builder.git/master and the rtems
> >> source tree from rtems.git/master.
> >> > It didn't produce the expected output. I instead got:
> >> > bash: ./waf: No such file or directory
> >> > As a result I downloaded it with the command:
> >> > curl https://waf.io/waf-2.0.19 > waf
> >> https://git.rtems.org/rtems/tree/waf
> >> Currently, the waf-based build of rtems only supports "in tree"
> >> builds, which means you need to run waf from within the rtems.git/
> >> root of your source. This is a limitation of the waf build.
> >> FWIW, waf build improvements could also fall under GSoC effort,
> >> although no one has written it up as a task yet. It would be mostly
> >> Python.
> >> > I ran the last command to configure the BSP again but still did not
> get the expected output. I got this rather:
> >> > Waf: Run from a folder containing a 'wscript' file (or try -h for the
> generic options)
> >> > Please how do I fix this? What am I missing?
> >> > I have tried looking for solutions but to no avail.
> >> Sometimes the solutions only exist inside other people's heads, so
> >> asking questions is encouraged.
> >> > Thanks,
> >> > Ida.
> >> > _______________________________________________
> >> > users mailing list
> >> > users at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/1f581ccb/attachment.html>
