Issues with configuring BSP with waf
Ida Delphine idadelm at gmail.com
Fri Mar 12 05:55:08 UTC 2021
Hello,
Please I need some help. Following the GSoC getting started guide(
https://docs.rtems.org/branches/master/user/start/gsoc.html),everything
went well to the point I had to do an offline download. I used this command
../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
Seems like there was a mismatch. I got this error:
RTEMS Source Builder - Set Builder, 6 (5e449fb5c2cb)
Build Set: 5/rtems-sparc
error: no build set file found: 5/rtems-sparc.bset
Build Set: Time 0:00:00.000205
Build FAILED
I then replaced 5/rtems in the command with 6/rtems and everything worked.
I was able to install the suite, build the board support package, and test
my BSP though along the way I had to replace "5" with "6" in certain
commands. Everything went well until I wanted to prove I can work on RTEMS.
I followed the instructions to create my hello application and added the
necessary .c files. The problem was when I tried configuring this
application using waf with the command:
./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
I got this error:
Setting top to                           :
/home/idadel/quick-start/app/hello
Setting out to                           :
/home/idadel/quick-start/app/hello/build
RTEMS path is not valid, "/home/idadel/quick-start/rtems/5/share/rtems5"
not found.
(complete log in /home/idadel/quick-start/app/hello/build/config.log)
I thought I showld startover but and work with rtems.git/5 instead of
rtems.git/master. Same with rsb. So I got the sources and did a "git
checkout"  from the master to the "5" branch. Everything went well with me
not not having to change any "5" to "6" in some commands. I didn't make it
as far as testing my BSP. I had issues with configuring my BSP with the
command:
I got this:
bash: ./waf: No such file or directory
I'm confused and don't know what I missed or where I went wrong.
Ida.
On Thu, Mar 11, 2021 at 6:03 PM Ida Delphine <idadelm at gmail.com> wrote:
> Okay. Thank you :)
> On Thu, 11 Mar 2021, 5:57 pm Gedare Bloom, <gedare at rtems.org> wrote:
>> On Thu, Mar 11, 2021 at 9:48 AM Ida Delphine <idadelm at gmail.com> wrote:
>> > Thank you for your response. I am not working on the rtems.git/master
>> branch. I'm not using it because earlier I tried downloading sources with
>> it but I got this error
>> > error: shell macro failed:
>> /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc
>> -l : 2: error: no library (-l) provided
>> > So I decided to use the other alternative(get the sources from releases)
>> > Since I'm a GSoC applicant should I wait till the issue at the master
>> branch is resolved?
>> Yes, that issue has been resolved so please try again. Hopefully,
>> things work a bit better. We try not to break things, but unexpected
>> problems come up from time to time, especially based on host OS
>> dependencies.
>> > Cheers,
>> > Ida.
>> > On Thu, Mar 11, 2021 at 4:18 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Thu, Mar 11, 2021 at 7:33 AM Ida Delphine <idadelm at gmail.com>
>> wrote:
>> >> > Hello everyone,
>> >> > Was following the quick build documentation and had issues around
>> where I have to do a manual BSP build.  In the last step of configuring the
>> BSP, I ran this command:
>> >> > ./waf configure --prefix=$HOME/quick-start/rtems/5
>> >> Are you working on rtems.git/master branch or /5 branch? Note that you
>> >> need to be sure to use a consistent compiler toolchain based on the
>> >> version of RTEMS that you use.
>> >> In rtems/5 branch we don't have waf support integrated yet. The
>> >> upgrade to waf is happening currently on the master branch, which will
>> >> eventually become the RTEMS version 6 release.
>> >> For GSoC students we expect development to happen on the development
>> >> head and not a release, so please make sure that you have the
>> >> toolchain built from rtems-source-builder.git/master and the rtems
>> >> source tree from rtems.git/master.
>> >> > It didn't produce the expected output. I instead got:
>> >> > As a result I downloaded it with the command:
>> >> > curl https://waf.io/waf-2.0.19 > waf
>> >> https://git.rtems.org/rtems/tree/waf
>> >> Currently, the waf-based build of rtems only supports "in tree"
>> >> builds, which means you need to run waf from within the rtems.git/
>> >> root of your source. This is a limitation of the waf build.
>> >> FWIW, waf build improvements could also fall under GSoC effort,
>> >> although no one has written it up as a task yet. It would be mostly
>> >> Python.
>> >> > I ran  the last command to configure the BSP again but still did not
>> get the expected  output. I got this rather:
>> >> > Waf: Run from a folder containing a 'wscript' file (or try -h for
>> the generic options)
>> >> > Please how do I fix this? What am I missing?
>> >> > I have tried looking for solutions but to no avail.
>> >> Sometimes the solutions only exist inside other people's heads, so
>> >> asking questions is encouraged.
>> >> > Thanks,
>> >> > Ida.
>> >> > _______________________________________________
>> >> > users mailing list
>> >> > users at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210312/cdc43a4a/attachment-0001.html>
