Installing rtems on 32 bit windows host machine
Thu Mar 11 19:11:48 UTC 2021
On Thu, Mar 11, 2021 at 1:05 PM Alireza Banejad <alibanejad1376 at gmail.com>
wrote:
> Hello everyone,
> I was wondering whether I could install RTEMS on a 32-bit Windows 7 host
> machine using either msys2 or Cygwin.
> I already tried installing it on msys2 i686 but when running sb-check it
> returns:
> error: exe: not found: (__cc)  i686-w32-mingw32-gccerror: exe: not found: (__cxx) i686-w32-mingw32-g++
> Environment is not correctly set up.
> It seems there is no such compiler as i686-w32-mingw32-gcc to add in the first place.
Assuming you have installed the gcc package, what is the compiler called?
I don't think any of the core developers have seen Windows 7 especially
32-bit in a while.
The file that sets the expectations based on host is
source-builder/sb/windows.py. It may require some tinkering to match a
32-bit environment.
We'd love to have a patch to that file (don't break 64-bit) and, if needed,
documentation.
--joel
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/ac9c8afe/attachment.html>
