Installing rtems on 32 bit windows host machine
Alireza Banejad alibanejad1376 at gmail.com
Thu Mar 11 19:05:08 UTC 2021
Hello everyone,
I was wondering whether I could install RTEMS on a 32-bit Windows 7 host
machine using either msys2 or Cygwin.
I already tried installing it on msys2 i686 but when running sb-check it
returns:
error: exe: not found: (__cc)  i686-w32-mingw32-gccerror: exe: not
found: (__cxx) i686-w32-mingw32-g++
Environment is not correctly set up.
It seems there is no such compiler as i686-w32-mingw32-gcc to add in
the first place.
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/71e33f62/attachment.html>
