instaling rtems on windows 10
Alireza Banejad alibanejad1376 at gmail.com
Wed Mar 17 11:06:46 UTC 2021
hello every one
I'm trying to  install rtems 6 arm toolchain on windows 10 but when the
source builder tries to build the rtems-gdb-10 it results in an error
reading the report gives me the following:
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe:
../gnulib/import/libgnu.a(getrandom.o): in function `getrandom':
C:\opt\rtems\rsb\rtems\build\argfxwm1\build\gnulib\import/../../../sourceware-mirror-binutils-gdb-fc9b4c8/gnulib/import/getrandom.c:129:
undefined reference to `BCryptGenRandom'
collect2.exe: error: ld returned 1 exit status
make[2]: *** [Makefile:1866: gdb.exe] Error 1
make[2]: Leaving directory '/c/opt/rtems/rsb/rtems/build/argfxwm1/build/gdb'
make[1]: *** [Makefile:9744: all-gdb] Error 2
make[1]: Leaving directory '/c/opt/rtems/rsb/rtems/build/argfxwm1/build'
make: *** [Makefile:866: all] Error 2
shell cmd failed: sh -ex  /c/opt/rtems/rsb/rtems/build/argfxwm1/do-build
error: building argfxwm1
Any thoughts?
URL: <http://lists.rtems.org/pipermail/users/attachments/20210317/0e7fb3ae/attachment.html>
