instaling rtems on windows 10
Wed Mar 17 17:58:25 UTC 2021
On Wed, Mar 17, 2021 at 5:07 AM Alireza Banejad
<alibanejad1376 at gmail.com> wrote:
> hello every one
> I'm trying to  install rtems 6 arm toolchain on windows 10 but when the source builder tries to build the rtems-gdb-10 it results in an error
> reading the report gives me the following:
> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: ../gnulib/import/libgnu.a(getrandom.o): in function `getrandom':
> C:\opt\rtems\rsb\rtems\build\argfxwm1\build\gnulib\import/../../../sourceware-mirror-binutils-gdb-fc9b4c8/gnulib/import/getrandom.c:129: undefined reference to `BCryptGenRandom'
This looks relevant:
http://sourceware-org.1504.n7.nabble.com/Unable-to-build-GDB-on-Windows-td649748.html
It seems that the configure probe for getrandom picks up libbcrypt
exists on your Windows, but then it does not get linked properly. This
seems to be a gdb build system problem. Possibly a newer gdb has fixed
it? You might be able to figure out how to add -lbcrypt to your linker
flags (export LDFLAGS=-lbcrypt   might just work) locally while
compiling GDB.
> collect2.exe: error: ld returned 1 exit status
> make[2]: *** [Makefile:1866: gdb.exe] Error 1
> make[2]: Leaving directory '/c/opt/rtems/rsb/rtems/build/argfxwm1/build/gdb'
> make[1]: *** [Makefile:9744: all-gdb] Error 2
> make[1]: Leaving directory '/c/opt/rtems/rsb/rtems/build/argfxwm1/build'
> make: *** [Makefile:866: all] Error 2
> shell cmd failed: sh -ex  /c/opt/rtems/rsb/rtems/build/argfxwm1/do-build
> error: building argfxwm1
> Any thoughts?
> users mailing list
> users at rtems.org
