RTEMS 5 how to run "hello" example
Olga Syrbachova
syrba4eva28 at gmail.com
Wed Mar 17 20:22:51 UTC 2021
Thank you very much for your reply! I'm still confused about all the
prefixes and PATHs. In the README.waf it is said to run
$ waf configure --rtems=$HOME/Development/rtems/5 \
--rtems-tools=$HOME/Development/rtems/5 \
--rtems-bsps=sparc/erc32
where $HOME/Development/rtems/build/5 is the path to tools and
$HOME/Development/rtems/build/5 is the path to RTEMS Board Support Packages.
I followed this tutorial
https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
installing RTEMS and building BSP. So in my case I built the tool suit
in development/rtems/src/rsb/rtems
$ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5
5/rtems-sparc
So the path to tools development/rtems/src/rsb/rtems, is it right? And I'm
not sure what is a path to RTEMS Board Support Packages.
On Wed, 17 Mar 2021 at 18:48, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 17, 2021 at 10:22 AM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
>> What do you mean "regular README file"? There are 3 of them: README,
>> README.Makefile and README.waf. In README there is just a list of examples.
>> I tried to follow the README.Makefile instructions, and after running:
> Thanks I forgot we put those instructions into README.Makefile.
>> olga at olga-H270M-DS3H:~/development/rtems-examples/hello/hello_world_c$
>> RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make
>> clean
>> and
>> there appeared an empty folder "o-optimize" in the examples's directory.
>> What's next?
>> Weird, I'll take a look. We do encourage to try to use waf to build the
> examples though, so let's focus on that direction.
>> And what do you mean "use ./waf"? When I run ./waf in "rtems-examples",
>> it says
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf
>> The project was not configured: run "waf configure" first!
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ waf configure --rtems=$HOME/development/rtems/build/5 \--rtems-tools=$HOME/development/rtems/5 \--rtems-bsps=sparc/erc32
> ./waf configure --rtems=$HOME/development/rtems/build/5
>> Command 'waf' not found, did you mean: ...
>> command 'paf' from deb libpod-abstract-perl
>> command 'wdf' from deb wit
>> On Wed, 17 Mar 2021 at 16:51, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 17, 2021 at 9:11 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>>> wrote:
>>>> Thanks a lot! I have one more stupid question. How do I run examples
>>>> from git? I've cloned rtems-examples and tried to follow the instructions
>>>> from "README.waf", but it doesn't work. When I enter
>>>> $ waf configure --rtems=$HOME/development/rtems/bsps/5 \
>>>> I get this error:
>>>> Use ./waf
>>>> I probably do something wrong. Do I need to do the instructions from "README.waf" at all? Or do I need to proceed as in this tutorial https://docs.rtems.org/branches/master/user/start/app.html with every example's directory? I would really appreciate some step-by-step tutorial or instructions as I'm totally frustrated right now and don't understand what to do.
>>>> Btw there is a makefile in every example's directory. Can I use it instead of waf to compile the applications? If this is the case how do I do it?
>>>> You can do either way of building the examples, see the regular README
>>> file for directions on the Makefile approach.
>>>> Many thanks in advance for any help!!!
>>>> On Tue, 16 Mar 2021 at 20:07, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Tue, Mar 16, 2021 at 1:40 PM Olga Syrbachova <syrba4eva28 at gmail.com>
>>>>> wrote:
>>>>>> Thank you very much for your reply and for your concern!
>>>>>> Actually I'd like to create my own application and test some
>>>>>> mechanisms, provided by RTEMS. This is a part of my Bachelor Thesis. I'd
>>>>>> like, for example, to create two/three tasks and make them communicate
>>>>>> with each other via queues, schedule them by priority etc. I have some
>>>>>> experience with FreeRTOS. It is run via Visual Studio, which is quite
>>>>>> simple. And now with RTEMS I am a bit frustrated and don't know where to
>>>>>> start. That's why I followed the tutorial on the Website. "Hello World"
>>>>>> program worked just fine, so I decided to try some more complicated
>>>>>> applications before I start with my own, that's why I decided to build
>>>>>> "ticker" with waf. Unfortunately I didn't find any helpful (for me)
>>>>>> tutorial on how to create applications in RTEMS. I mean I can handle
>>>>>> writing the App's code, but I don't get it how to compile and run it. So I
>>>>>> was just going to do the same as in the tutorial, but with my own
>>>>>> application. Is it the right way to proceed or is there another way ?
>>>>> The tests in RTEMS are just that tests. They depend on things that
>>>>> shouldn't be installed or used by user applications.
>>>>> I would recommend cloning rtems-examples and going from one of those.
>>>>> There is a directory with variations on ticker and I suspect the base one
>>>>> is a better one to start from.
>>>>> If you want to write POSIX code, one of the POSIX examples there would
>>>>> serve you ok
>>>>> --joel
>>>>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
>>>>>> www.avast.com
>>>>>> <#m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>> On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <vijay at rtems.org>
>>>>>> wrote:
>>>>>>> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <
>>>>>>> > I've added
>>>>>>> > includes =
>>>>>>> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
>>>>>>> It takes the relative address to the directory where the header file
>>>>>>> is. For example, if you're building from the
>>>>>>> "/home/olga/development/rtems" directory the includes argument would
>>>>>>> be:
>>>>>>> `includes = './rtems-5/testsuites/support/include/'`
>>>>>>> BTW, your first email at the start of the thread says that you just
>>>>>>> want to run the samples, the samples get built as a part of the rtems
>>>>>>> and you'll be able to see the *.exe files in the build directory. Is
>>>>>>> there any reason that you're trying to build it in a separate
>>>>>>> directory with waf? Experimenting with the build system is a good
>>>>>>> reason though, just making sure that we're not pushing you in the
>>>>>>> wrong direction and your objective is indeed to try waf on your own
>>>>>>> and not just running RTEMS hello app.
>>>>>>> Best regards,
>>>>>>> Vijay
>>>>>>> > it still says "No such file or directory". I'm pretty sure the
>>>>>>> path is write, though there is now another path to "tmacros.h" (the first
>>>>>>> one below), it's a folder named "tmacros.h" and it's empty.
>>>>>>> > olga at olga-H270M-DS3H:~$ locate tmacros.h
>>>>>>> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
>>>>>>> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <
>>>>>>> vijay at rtems.org> wrote:
>>>>>>> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <
>>>>>>> >> > Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
>>>>>>> >> Thanks. In this line:
>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
>>>>>>> >> After cflags parameter, add "includes", for example:
>>>>>>> >> bld(features = 'c cprogram',
>>>>>>> >> target = 'ticker.exe',
>>>>>>> >> cflags = '-g -O2',
>>>>>>> >> includes='. .. ./original/path/to/tmacros.h',
>>>>>>> >> source = ['init.c', 'tasks.c'])
>>>>>>> >> you don't need to copy tmacros.h or any headers from rtems, just
>>>>>>> add
>>>>>>> >> the path to includes.
>>>>>>> >> Best regards,
>>>>>>> >> Vijay
>>>>>>> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <
>>>>>>> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
>>>>>>> >> >> > Unfortunately I'm still a bit confused and don't quite
>>>>>>> understand what to do. Where do I need to modify the "include" parameter?
>>>>>>> In the wscript file from the "hello" example there is no "include"
>>>>>>> parameter. I also tried to find a tutorial on how to write a wscript, but
>>>>>>> didn't find any (Could you suggest any please?). So I tried to copy the
>>>>>>> file "tmacros.h" from testsuites/support/include to app/ticker. Now after
>>>>>>> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
>>>>>>> found. When I copied it to my app/ticker directory it didn't work and I
>>>>>>> still have the same error.
>>>>>>> >> >> Would it be possible for you to paste your wscript somewhere
>>>>>>> (like
>>>>>>> >> >> gist.github.com) and share it here so that we can have a look
>>>>>>> and help
>>>>>>> >> >> you with that?
>>>>>>> >> >> Best regards,
>>>>>>> >> >> Vijay
>>>>>>> >> >> > Waf: Entering directory
>>>>>>> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>>>>>>> >> >> > [1/3] Compiling tasks.c
>>>>>>> >> >> > [2/3] Compiling init.c
>>>>>>> >> >> > In file included from ../../system.h:17:0,
>>>>>>> >> >> > from ../../init.c:15:
>>>>>>> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No
>>>>>>> >> >> > #include <buffer_test_io.h>
>>>>>>> >> >> > compilation terminated.
>>>>>>> >> >> > from ../../tasks.c:22:
>>>>>>> >> >> > Waf: Leaving directory
>>>>>>> >> >> > Build failed
>>>>>>> >> >> > -> task in 'ticker.exe' failed with exit status 1 (run with
>>>>>>> -v to display more information)
>>>>>>> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
>>>>>>> >> >> >> Hi Olga,
>>>>>>> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
>>>>>>> >> >> >> > I've built the RTEMS Kernel for erc32. Then I followed
>>>>>>> this tutorial
>>>>>>> https://docs.rtems.org/branches/master/user/start/app.html to build
>>>>>>> a "Hello World" application and it works just fine. Then I've tried to
>>>>>>> create another application following the steps in the tutorial.
>>>>>>> >> >> >> > 1. In $HOME/development/app/ I created a directory
>>>>>>> "ticker".
>>>>>>> >> >> >> > 2. cd ticker
>>>>>>> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>>>>>>> >> >> >> > chmod +x waf
>>>>>>> >> >> >> > git init
>>>>>>> >> >> >> > git submodule add git://git.rtems.org/rtems_waf.git
>>>>>>> rtems_waf
>>>>>>> >> >> >> > 4. I've copied the files "init.c", "tasks.c", "system.h"
>>>>>>> from testsuites/samples
>>>>>>> >> >> >> > 5. In the "wscript" I've changed the lines 32 and 34 to
>>>>>>> target = 'ticker.exe', source = ['init.c', 'tasks.c']
>>>>>>> >> >> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5
>>>>>>> --rtems-bsp=sparc/erc32
>>>>>>> >> >> >> > 7. and running ./waf next, I get an error. It looks like
>>>>>>> the file "tmacros.h", which is included in "system.h", cannot be found.
>>>>>>> >> >> >> You have changed the "target" and "source" parameters in
>>>>>>> your wscript.
>>>>>>> >> >> >> You'd also need to modify the "include" parameter and add
>>>>>>> relative
>>>>>>> >> >> >> path to tmacros.h. For multiple headers, you'll have to add
>>>>>>> the paths
>>>>>>> >> >> >> as a string with space-separated values or a list like this:
>>>>>>> >> >> >> `includes='./ ../ ./path/to/include/'`
>>>>>>> >> >> >> > What am I doing wrong? Is the way to run other examples
>>>>>>> exactly the same as to run a "Hello World" example?
>>>>>>> >> >> >> The other examples will also follow a similar wscript
>>>>>>> structure but
>>>>>>> >> >> >> hello world is the simple one with fewer includes so it's a
>>>>>>> good place
>>>>>>> >> >> >> to start if you're trying to learn how to make a separate
>>>>>>> project with
>>>>>>> >> >> >> RTEMS applications using waf.
>>>>>>> >> >> >> Best regards,
>>>>>>> >> >> >> Vijay
>>>>>>> >> >> >> > _______________________________________________
>>>>>>> >> >> >> > users mailing list
>>>>>>> >> >> >> > users at rtems.org
>>>>>>> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
>>>>>> www.avast.com
>>>>>> <#m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>> users mailing list
>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210317/bae53a1d/attachment-0001.html>
