RTEMS 5 how to run "hello" example
Wed Mar 17 21:43:30 UTC 2021
On Wed, Mar 17, 2021 at 2:23 PM Olga Syrbachova <syrba4eva28 at gmail.com>
wrote:
> Thank you very much for your reply! I'm still confused about all the
> prefixes and PATHs. In the README.waf it is said to run
> $ waf configure --rtems=$HOME/Development/rtems/5 \
> --rtems-tools=$HOME/Development/rtems/5 \
> --rtems-bsps=sparc/erc32
> where $HOME/Development/rtems/build/5 is the path to tools and
> $HOME/Development/rtems/build/5 is the path to RTEMS Board Support
> Packages.
> I followed this tutorial
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> installing RTEMS and building BSP. So in my case I built the tool suit in development/rtems/src/rsb/rtems
> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5 5/rtems-sparc
> So the path to tools development/rtems/src/rsb/rtems, is it right? And
> I'm not sure what is a path to RTEMS Board Support Packages.
Since you build version 5, you need to specify that to waf, otherwise it
defaults to try to build the current RTEMS development version, try
./waf configure --rtems=$HOME/Development/rtems/5 \
  --rtems-bsps=sparc/erc32 \
  --rtems-version=5
I think we will need some updates to the README.waf for version management.
Patches are welcome :)
On Wed, 17 Mar 2021 at 18:48, Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Mar 17, 2021 at 10:22 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>> wrote:
>>> What do you mean "regular README file"? There are 3 of them: README,
>>> README.Makefile and README.waf. In README there is just a list of examples.
>>> I tried to follow the README.Makefile instructions, and after running:
>> Thanks I forgot we put those instructions into README.Makefile.
>>> olga at olga-H270M-DS3H:~/development/rtems-examples/hello/hello_world_c$
>>> RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make
>>> clean
>>> and
>>> there appeared an empty folder "o-optimize" in the examples's directory.
>>> What's next?
>>> Weird, I'll take a look. We do encourage to try to use waf to build the
>> examples though, so let's focus on that direction.
>>> And what do you mean "use ./waf"? When I run ./waf in "rtems-examples",
>>> it says
>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf
>>> The project was not configured: run "waf configure" first!
>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ waf configure --rtems=$HOME/development/rtems/build/5 \--rtems-tools=$HOME/development/rtems/5 \--rtems-bsps=sparc/erc32
>>  ./waf configure --rtems=$HOME/development/rtems/build/5
>>> Command 'waf' not found, did you mean: ...
>>>   command 'paf' from deb libpod-abstract-perl
>>>   command 'wdf' from deb wit
>>> On Wed, 17 Mar 2021 at 16:51, Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Wed, Mar 17, 2021 at 9:11 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>>>> wrote:
>>>>> Thanks a lot! I have one more stupid question. How do I run examples
>>>>> from git? I've cloned rtems-examples and tried to follow the instructions
>>>>> from "README.waf", but it doesn't work. When I enter
>>>>>     $ waf configure --rtems=$HOME/development/rtems/bsps/5 \
>>>>> I get this error:
>>>>> Use ./waf
>>>>> I probably do something wrong. Do I need to do the instructions from "README.waf" at all? Or do I need to proceed as in this tutorial https://docs.rtems.org/branches/master/user/start/app.html with every example's directory? I would really appreciate some step-by-step tutorial or instructions as I'm totally frustrated right now and don't understand what to do.
>>>>> Btw there is a makefile in every example's directory. Can I use it instead of waf to compile the applications? If this is the case how do I do it?
>>>>> You can do either way of building the examples, see the regular README
>>>> file for directions on the Makefile approach.
>>>>> Many thanks in advance for any help!!!
>>>>> On Tue, 16 Mar 2021 at 20:07, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Tue, Mar 16, 2021 at 1:40 PM Olga Syrbachova <
>>>>>> syrba4eva28 at gmail.com> wrote:
>>>>>>> Thank you very much for your reply and for your concern!
>>>>>>> Actually I'd like to create my own application and test some
>>>>>>> mechanisms, provided by RTEMS. This is a part of my Bachelor Thesis. I'd
>>>>>>> like, for example, to create two/three tasks and make them communicate
>>>>>>> with each other via queues, schedule them by priority etc. I have some
>>>>>>> experience with FreeRTOS. It is run via Visual Studio, which is quite
>>>>>>> simple. And now with RTEMS I am a bit frustrated and don't know where to
>>>>>>> start. That's why I followed the tutorial on the Website. "Hello World"
>>>>>>> program worked just fine, so I decided to try some more complicated
>>>>>>> applications before I start with my own, that's why I decided to build
>>>>>>> "ticker" with waf. Unfortunately I didn't find any helpful (for me)
>>>>>>> tutorial on how to create applications in RTEMS. I mean I can handle
>>>>>>> writing the App's code, but I don't get it how to compile and run it. So I
>>>>>>> was just going to do the same as in the tutorial, but with my own
>>>>>>> application. Is it the right way to proceed or is there another way ?
>>>>>> The tests in RTEMS are just that tests. They depend on things that
>>>>>> shouldn't be installed or used by user applications.
>>>>>> I would recommend cloning rtems-examples and going from one of those.
>>>>>> There is a directory with variations on ticker and I suspect the base one
>>>>>> is a better one to start from.
>>>>>> If you want to write POSIX code, one of the POSIX examples there
>>>>>> would serve you ok
>>>>>> --joel
>>>>>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
>>>>>>> www.avast.com
>>>>>>> <#m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>> On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <vijay at rtems.org>
>>>>>>> wrote:
>>>>>>>> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <
>>>>>>>> > I've added
>>>>>>>> > includes =
>>>>>>>> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
>>>>>>>> It takes the relative address to the directory where the header file
>>>>>>>> is. For example, if you're building from the
>>>>>>>> "/home/olga/development/rtems" directory the includes argument would
>>>>>>>> be:
>>>>>>>> `includes = './rtems-5/testsuites/support/include/'`
>>>>>>>> BTW, your first email at the start of the thread says that you just
>>>>>>>> want to run the samples, the samples get built as a part of the
>>>>>>>> rtems
>>>>>>>> and you'll be able to see the *.exe files in the build directory. Is
>>>>>>>> there any reason that you're trying to build it in a separate
>>>>>>>> directory with waf? Experimenting with the build system is a good
>>>>>>>> reason though, just making sure that we're not pushing you in the
>>>>>>>> wrong direction and your objective is indeed to try waf on your own
>>>>>>>> and not just running RTEMS hello app.
>>>>>>>> Best regards,
>>>>>>>> Vijay
>>>>>>>> > it still says "No such file or directory". I'm pretty sure the
>>>>>>>> path is write, though there is now another path to "tmacros.h" (the first
>>>>>>>> one below), it's a folder named "tmacros.h" and it's empty.
>>>>>>>> > olga at olga-H270M-DS3H:~$ locate tmacros.h
>>>>>>>> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
>>>>>>>> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <
>>>>>>>> vijay at rtems.org> wrote:
>>>>>>>> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <
>>>>>>>> >> > Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
>>>>>>>> >> Thanks. In this line:
>>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
>>>>>>>> >> After cflags parameter, add "includes", for example:
>>>>>>>> >> bld(features = 'c cprogram',
>>>>>>>> >>       target = 'ticker.exe',
>>>>>>>> >>       cflags = '-g -O2',
>>>>>>>> >>       includes='. .. ./original/path/to/tmacros.h',
>>>>>>>> >>       source = ['init.c', 'tasks.c'])
>>>>>>>> >> you don't need to copy tmacros.h or any headers from rtems, just
>>>>>>>> add
>>>>>>>> >> the path to includes.
>>>>>>>> >> Best regards,
>>>>>>>> >> Vijay
>>>>>>>> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <
>>>>>>>> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
>>>>>>>> >> >> > Unfortunately I'm still a bit confused and don't quite
>>>>>>>> understand what to do. Where do I need to modify the "include" parameter?
>>>>>>>> In the wscript file from the "hello" example there is no "include"
>>>>>>>> parameter. I also tried to find a tutorial on how to write a wscript, but
>>>>>>>> didn't find any (Could you suggest any please?). So I tried to copy the
>>>>>>>> file "tmacros.h" from testsuites/support/include to app/ticker. Now after
>>>>>>>> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
>>>>>>>> found. When I copied it to my app/ticker directory it didn't work and I
>>>>>>>> still have the same error.
>>>>>>>> >> >> Would it be possible for you to paste your wscript somewhere
>>>>>>>> (like
>>>>>>>> >> >> gist.github.com) and share it here so that we can have a
>>>>>>>> look and help
>>>>>>>> >> >> you with that?
>>>>>>>> >> >> Best regards,
>>>>>>>> >> >> Vijay
>>>>>>>> >> >> > Waf: Entering directory
>>>>>>>> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>>>>>>>> >> >> > [1/3] Compiling tasks.c
>>>>>>>> >> >> > [2/3] Compiling init.c
>>>>>>>> >> >> > In file included from ../../system.h:17:0,
>>>>>>>> >> >> >                  from ../../init.c:15:
>>>>>>>> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No
>>>>>>>> >> >> >  #include <buffer_test_io.h>
>>>>>>>> >> >> > compilation terminated.
>>>>>>>> >> >> >                  from ../../tasks.c:22:
>>>>>>>> >> >> > Waf: Leaving directory
>>>>>>>> >> >> > Build failed
>>>>>>>> >> >> >  -> task in 'ticker.exe' failed with exit status 1 (run
>>>>>>>> with -v to display more information)
>>>>>>>> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
>>>>>>>> >> >> >> Hi Olga,
>>>>>>>> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
>>>>>>>> >> >> >> > I've built the RTEMS Kernel for erc32. Then I followed
>>>>>>>> this tutorial
>>>>>>>> https://docs.rtems.org/branches/master/user/start/app.html to
>>>>>>>> build a "Hello World" application and it works just fine. Then I've tried
>>>>>>>> to create another application following the steps in the tutorial.
>>>>>>>> >> >> >> > 1. In $HOME/development/app/ I created a directory
>>>>>>>> "ticker".
>>>>>>>> >> >> >> > 2. cd ticker
>>>>>>>> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>>>>>>>> >> >> >> >     chmod +x waf
>>>>>>>> >> >> >> >     git init
>>>>>>>> >> >> >> >     git submodule add git://git.rtems.org/rtems_waf.git
>>>>>>>> rtems_waf
>>>>>>>> >> >> >> > 4. I've copied the files "init.c", "tasks.c", "system.h"
>>>>>>>> from testsuites/samples
>>>>>>>> >> >> >> > 5. In the "wscript" I've changed the lines 32 and 34 to
>>>>>>>> target = 'ticker.exe', source = ['init.c', 'tasks.c']
>>>>>>>> >> >> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5
>>>>>>>> --rtems-bsp=sparc/erc32
>>>>>>>> >> >> >> > 7. and running ./waf next, I get an error. It looks like
>>>>>>>> the file "tmacros.h", which is included in "system.h", cannot be found.
>>>>>>>> >> >> >> You have changed the "target" and "source" parameters in
>>>>>>>> your wscript.
>>>>>>>> >> >> >> You'd also need to modify the "include" parameter and add
>>>>>>>> relative
>>>>>>>> >> >> >> path to tmacros.h. For multiple headers, you'll have to
>>>>>>>> add the paths
>>>>>>>> >> >> >> as a string with space-separated values or a list like
>>>>>>>> this:
>>>>>>>> >> >> >> `includes='./ ../ ./path/to/include/'`
>>>>>>>> >> >> >> > What am I doing wrong? Is the way to run other examples
>>>>>>>> exactly the same as to run a "Hello World" example?
>>>>>>>> >> >> >> The other examples will also follow a similar wscript
>>>>>>>> structure but
>>>>>>>> >> >> >> hello world is the simple one with fewer includes so it's
>>>>>>>> a good place
>>>>>>>> >> >> >> to start if you're trying to learn how to make a separate
>>>>>>>> project with
>>>>>>>> >> >> >> RTEMS applications using waf.
>>>>>>>> >> >> >> Best regards,
>>>>>>>> >> >> >> Vijay
>>>>>>>> >> >> >> > _______________________________________________
>>>>>>>> >> >> >> > users mailing list
>>>>>>>> >> >> >> > users at rtems.org
>>>>>>>> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
>>>>>>> www.avast.com
>>>>>>> <#m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>> users mailing list
>>>>>>> users at rtems.org
>>>>> users mailing list
>>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210317/a5132ba7/attachment-0001.html>
