RTEMS 5 how to run "hello" example
Olga Syrbachova
syrba4eva28 at gmail.com
Thu Mar 18 20:01:04 UTC 2021
The output of the waf configure:
Checking for program 'rtems-tld' :
/home/olga/development/rtems/5/bin/rtems-tld
Checking for a valid RTEMS BSP installation : yes
Checking for RTEMS_DEBUG : no
Checking for RTEMS_MULTIPROCESSING : no
Checking for RTEMS_NEWLIB : yes
Checking for RTEMS_POSIX_API : yes
Checking for RTEMS_SMP : no
Checking for RTEMS_NETWORKING : yes
Library libm.a : found
Library liblvgl.a : not found
Library libbsd.a : not found
'configure' finished successfully (1.898s)
And after running ./waf -v there is a lot of text and it ends with:
error: sparc/erc32: RTEMS BSP not found
Waf: Leaving directory
`/home/olga/development/rtems-examples/build/sparc-rtems5-erc32'
Build failed
-> task in 'both_hello.texe' failed with exit status 10:
{task 139851944010448: rtrace test.c.1.o -> both_hello.texe}
['/home/olga/development/rtems/5/bin/rtems-tld', '-W hello-test', '-C',
'../../hello/both_hello/hello.ini', '-r', '/home/olga/development/rtems/5',
'-B', 'sparc/erc32', '-c',
'/home/olga/development/rtems/5/bin/sparc-rtems5-gcc', '-l',
'/home/olga/development/rtems/5/bin/sparc-rtems5-gcc', '--',
'hello/both_hello/test.c.1.o', '-qrtems',
'-B/home/olga/development/rtems/5/sparc-rtems5/lib/',
'-B/home/olga/development/rtems/5/sparc-rtems5/erc32/lib/', '--specs',
'bsp_specs', '-mcpu=cypress', '-ffunction-sections', '-fdata-sections',
'-MMD', '-Wl,--gc-sections', '-o',
'/home/olga/development/rtems-examples/build/sparc-rtems5-erc32/hello/both_hello/both_hello.texe',
'-Wl,-Bstatic']
-> task in 'hello-deep.texe' failed with exit status 10:
{task 139851944010704: rtrace test.c.2.o -> hello-deep.texe}
['/home/olga/development/rtems/5/bin/rtems-tld', '-W hello-deep', '-C',
'../../hello/both_hello/hello-deep.ini', '-r',
'/home/olga/development/rtems/5', '-B', 'sparc/erc32', '-c',
'hello/both_hello/test.c.2.o', '-qrtems',
'/home/olga/development/rtems-examples/build/sparc-rtems5-erc32/hello/both_hello/hello-deep.texe',
'-Wl,-Bstatic']
On Thu, 18 Mar 2021 at 20:50, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 18, 2021 at 10:30 AM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
>> Thanks a lot, one step further :)
>> 'configure' finished successfully (8.331s)
>> And again an error.
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf
>> Waf: Entering directory
>> [ 1/14] Compiling hello/hello_world_c/test.c
>> [ 2/14] Compiling hello/posix_hello_world/test.c
>> [ 3/14] Compiling hello/both_hello/test.c
>> [ 4/14] Compiling hello/both_hello/test.c
>> [ 5/14] Compiling hello/both_hello/test.c
>> [ 6/14] Linking build/sparc-rtems5-erc32/hello/hello_world_c/hello.exe
>> [ 7/14] Linking
>> build/sparc-rtems5-erc32/hello/posix_hello_world/posix_hello.exe
>> [ 8/14] Compiling build/sparc-rtems5-erc32/hello/both_hello/test.c.1.o
>> Build failed
>> -> task in 'both_hello.texe' failed with exit status 10 (run with -v to
>> display more information)
> That's a curious error. I suggest run ./waf -v
> the .texe is tracing related, so there is something going wrong with your
> trace-linker. Show the output of waf configure, did it find rtems-tld?
>> $HOME/development/rtems/5/bin/sparc-rtems5-run \
>> > ./build/sparc-rtems5-erc32/hello
>> bash: /home/olga/development/rtems/5/bin/sparc-rtems5-run: No such file
>> or directory
>> And I also have another question: why is only "hello" example built? I've
>> been doing all the steps in the "rtems-examples" directory and thought that
>> every example will be built. Do I have to build and run an example in the
>> directory of the example?
>> Because of the error on the texe, the build stops there. Otherwise it
> should build all of them when you run waf from the top-level directory like
> that.
>> On Thu, 18 Mar 2021 at 17:06, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, Mar 18, 2021 at 3:22 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>>> wrote:
>>>> Thank you very much for your reply! I really appreciate that someone is
>>>> still trying to help me after so many questions from me :)
>>>> I've got an error again, so I will describe here all my steps in case
>>>> I'm doing something wrong and you can see where the problem could be.
>>>> 1.
>>>> olga at olga-H270M-DS3H:~/development$ git clone git://
>>>> git.rtems.org/rtems-examples.git
>>>> 2.
>>>> olga at olga-H270M-DS3H:~/development$ cd rtems-examples
>>>> 3.
>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule init
>>>> Submodule 'rtems_waf' (git://git.rtems.org/rtems_waf.git) registered
>>>> for path 'rtems_waf'
>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule update
>>>> Cloning into '/home/olga/development/rtems-examples/rtems_waf'...
>>>> Submodule path 'rtems_waf': checked out 'ad0890
>>>> 4.
>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf configure
>>>> --rtems=$HOME/development/rtems/5 --rtems-tools=$HOME/development/rtems/5
>>>> --rtems-bsps=sparc/erc32
>>> Here, you need to add --rtems-version or it defaults to 6:
>>> ./waf configure --rtems=$HOME/development/rtems/5
>>> --rtems-tools=$HOME/development/rtems/5 --rtems-bsps=sparc/erc32
>>> --rtems-version=5
>>>> Setting top to :
>>>> Setting out to :
>>>> RTEMS path is not valid, "/home/olga/development/rtems/5/share/rtems6"
>>>> not found.
>>>> (complete log in /home/olga/development/rtems-examples/build/config.log)
>>>> 8c452c6a9bbb3bf7bbbcc9fc03fe46cc7f'
>>>> As it was suggested by Gedare Bloom before: "We do encourage to try to
>>>> use waf to build the examples though, so let's focus on that direction." I
>>>> would really like to understand how to build the examples and later my own
>>>> apps using waf :)
>>>> Great. It should also work to build applications with Makefile or any
>>> other kind of build system, but the trick is how to extract the build
>>> configuration/variables that were used for RTEMS. We are (slowly) moving
>>> toward an interface to get at those variables, with the rtems_waf module
>>> providing the state-of-the-art and best developed method.
>>>> On Wed, 17 Mar 2021 at 22:49, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Wed, Mar 17, 2021 at 2:23 PM Olga Syrbachova <syrba4eva28 at gmail.com>
>>>>> wrote:
>>>>>> Thank you very much for your reply! I'm still confused about all the
>>>>>> prefixes and PATHs. In the README.waf it is said to run
>>>>>> $ waf configure --rtems=$HOME/Development/rtems/5 \
>>>>>> --rtems-tools=$HOME/Development/rtems/5 \
>>>>>> where $HOME/Development/rtems/build/5 is the path to tools and
>>>>>> $HOME/Development/rtems/build/5 is the path to RTEMS Board Support
>>>>>> Packages.
>>>>>> I followed this tutorial
>>>>>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>>>>>> installing RTEMS and building BSP. So in my case I built the tool suit in development/rtems/src/rsb/rtems
>>>>>> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5 5/rtems-sparc
>>>>>> So the path to tools development/rtems/src/rsb/rtems, is it right? And
>>>>>> I'm not sure what is a path to RTEMS Board Support Packages.
>>>>> All paths referenced by README.waf are installed paths, i.e., the
>>>>> prefix that you used. It looks like that would be $HOME/development/rtems/5
>>>>> for your case, for the tools (as passed to sb-set-builder) and for rtems
>>>>> (if you followed that blog post, it specifies the prefix to configure).
>>>>>> On Wed, 17 Mar 2021 at 18:48, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>> On Wed, Mar 17, 2021 at 10:22 AM Olga Syrbachova <
>>>>>>> syrba4eva28 at gmail.com> wrote:
>>>>>>>> What do you mean "regular README file"? There are 3 of them:
>>>>>>>> README, README.Makefile and README.waf. In README there is just a list of
>>>>>>>> examples.
>>>>>>>> I tried to follow the README.Makefile instructions, and after
>>>>>>>> running:
>>>>>>> Thanks I forgot we put those instructions into README.Makefile.
>>>>>>>> olga at olga-H270M-DS3H:~/development/rtems-examples/hello/hello_world_c$
>>>>>>>> RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make
>>>>>>>> clean
>>>>>>>> and
>>>>>>>> there appeared an empty folder "o-optimize" in the examples's
>>>>>>>> directory. What's next?
>>>>>>>> Weird, I'll take a look. We do encourage to try to use waf to build
>>>>>> BTW: This worked for me. If you like, you can show what is the
>>>>> terminal output from the second line
>>>>> `RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make`?
>>>>>> And what do you mean "use ./waf"? When I run ./waf in
>>>>>>>> "rtems-examples", it says
>>>>>>>> The project was not configured: run "waf configure" first!
>>>>>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ waf configure --rtems=$HOME/development/rtems/build/5 \--rtems-tools=$HOME/development/rtems/5 \--rtems-bsps=sparc/erc32
>>>>>>> ./waf configure --rtems=$HOME/development/rtems/build/5
>>>>>>>> Command 'waf' not found, did you mean: ...
>>>>>>>> command 'paf' from deb libpod-abstract-perl
>>>>>>>> command 'wdf' from deb wit
>>>>>>>> On Wed, 17 Mar 2021 at 16:51, Gedare Bloom <gedare at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> On Wed, Mar 17, 2021 at 9:11 AM Olga Syrbachova <
>>>>>>>>>> Thanks a lot! I have one more stupid question. How do I run
>>>>>>>>>> examples from git? I've cloned rtems-examples and tried to follow the
>>>>>>>>>> instructions from "README.waf", but it doesn't work. When I enter
>>>>>>>>>> $ waf configure --rtems=$HOME/development/rtems/bsps/5 \
>>>>>>>>>> I get this error:
>>>>>>>>>> Use ./waf
>>>>>>>>>> I probably do something wrong. Do I need to do the instructions from "README.waf" at all? Or do I need to proceed as in this tutorial https://docs.rtems.org/branches/master/user/start/app.html with every example's directory? I would really appreciate some step-by-step tutorial or instructions as I'm totally frustrated right now and don't understand what to do.
>>>>>>>>>> Btw there is a makefile in every example's directory. Can I use it instead of waf to compile the applications? If this is the case how do I do it?
>>>>>>>>>> You can do either way of building the examples, see the regular
>>>>>>>>> README file for directions on the Makefile approach.
>>>>>>>>>> Many thanks in advance for any help!!!
>>>>>>>>>> On Tue, 16 Mar 2021 at 20:07, Joel Sherrill <joel at rtems.org>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Tue, Mar 16, 2021 at 1:40 PM Olga Syrbachova <
>>>>>>>>>>>> Thank you very much for your reply and for your concern!
>>>>>>>>>>>> Actually I'd like to create my own application and test some
>>>>>>>>>>>> mechanisms, provided by RTEMS. This is a part of my Bachelor Thesis. I'd
>>>>>>>>>>>> like, for example, to create two/three tasks and make them communicate
>>>>>>>>>>>> with each other via queues, schedule them by priority etc. I have some
>>>>>>>>>>>> experience with FreeRTOS. It is run via Visual Studio, which is quite
>>>>>>>>>>>> simple. And now with RTEMS I am a bit frustrated and don't know where to
>>>>>>>>>>>> start. That's why I followed the tutorial on the Website. "Hello World"
>>>>>>>>>>>> program worked just fine, so I decided to try some more complicated
>>>>>>>>>>>> applications before I start with my own, that's why I decided to build
>>>>>>>>>>>> "ticker" with waf. Unfortunately I didn't find any helpful (for me)
>>>>>>>>>>>> tutorial on how to create applications in RTEMS. I mean I can handle
>>>>>>>>>>>> writing the App's code, but I don't get it how to compile and run it. So I
>>>>>>>>>>>> was just going to do the same as in the tutorial, but with my own
>>>>>>>>>>>> application. Is it the right way to proceed or is there another way ?
>>>>>>>>>>> The tests in RTEMS are just that tests. They depend on things
>>>>>>>>>>> that shouldn't be installed or used by user applications.
>>>>>>>>>>> I would recommend cloning rtems-examples and going from one of
>>>>>>>>>>> those. There is a directory with variations on ticker and I suspect the
>>>>>>>>>>> base one is a better one to start from.
>>>>>>>>>>> If you want to write POSIX code, one of the POSIX examples there
>>>>>>>>>>> would serve you ok
>>>>>>>>>>> --joel
>>>>>>>>>>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
>>>>>>>>>>>> www.avast.com
>>>>>>>>>>>> <#m_-356064547562217854_m_-9076596597508598725_m_7917335146911979221_m_-3453968078082772622_m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>>>>>> On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <
>>>>>>>>>>>> vijay at rtems.org> wrote:
>>>>>>>>>>>>> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <
>>>>>>>>>>>>> > I've added
>>>>>>>>>>>>> > includes =
>>>>>>>>>>>>> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
>>>>>>>>>>>>> It takes the relative address to the directory where the
>>>>>>>>>>>>> header file
>>>>>>>>>>>>> is. For example, if you're building from the
>>>>>>>>>>>>> "/home/olga/development/rtems" directory the includes argument
>>>>>>>>>>>>> would
>>>>>>>>>>>>> be:
>>>>>>>>>>>>> `includes = './rtems-5/testsuites/support/include/'`
>>>>>>>>>>>>> BTW, your first email at the start of the thread says that you
>>>>>>>>>>>>> just
>>>>>>>>>>>>> want to run the samples, the samples get built as a part of
>>>>>>>>>>>>> the rtems
>>>>>>>>>>>>> and you'll be able to see the *.exe files in the build
>>>>>>>>>>>>> directory. Is
>>>>>>>>>>>>> there any reason that you're trying to build it in a separate
>>>>>>>>>>>>> directory with waf? Experimenting with the build system is a
>>>>>>>>>>>>> good
>>>>>>>>>>>>> reason though, just making sure that we're not pushing you in
>>>>>>>>>>>>> the
>>>>>>>>>>>>> wrong direction and your objective is indeed to try waf on
>>>>>>>>>>>>> your own
>>>>>>>>>>>>> and not just running RTEMS hello app.
>>>>>>>>>>>>> Best regards,
>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>> > it still says "No such file or directory". I'm pretty sure
>>>>>>>>>>>>> the path is write, though there is now another path to "tmacros.h" (the
>>>>>>>>>>>>> first one below), it's a folder named "tmacros.h" and it's empty.
>>>>>>>>>>>>> > olga at olga-H270M-DS3H:~$ locate tmacros.h
>>>>>>>>>>>>> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
>>>>>>>>>>>>> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <
>>>>>>>>>>>>> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <
>>>>>>>>>>>>> >> > Sure!
>>>>>>>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript
>>>>>>>>>>>>> >> Thanks. In this line:
>>>>>>>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
>>>>>>>>>>>>> >> After cflags parameter, add "includes", for example:
>>>>>>>>>>>>> >> bld(features = 'c cprogram',
>>>>>>>>>>>>> >> target = 'ticker.exe',
>>>>>>>>>>>>> >> cflags = '-g -O2',
>>>>>>>>>>>>> >> includes='. .. ./original/path/to/tmacros.h',
>>>>>>>>>>>>> >> source = ['init.c', 'tasks.c'])
>>>>>>>>>>>>> >> you don't need to copy tmacros.h or any headers from rtems,
>>>>>>>>>>>>> just add
>>>>>>>>>>>>> >> the path to includes.
>>>>>>>>>>>>> >> Best regards,
>>>>>>>>>>>>> >> Vijay
>>>>>>>>>>>>> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <
>>>>>>>>>>>>> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
>>>>>>>>>>>>> >> >> > Unfortunately I'm still a bit confused and don't quite
>>>>>>>>>>>>> understand what to do. Where do I need to modify the "include" parameter?
>>>>>>>>>>>>> In the wscript file from the "hello" example there is no "include"
>>>>>>>>>>>>> parameter. I also tried to find a tutorial on how to write a wscript, but
>>>>>>>>>>>>> didn't find any (Could you suggest any please?). So I tried to copy the
>>>>>>>>>>>>> file "tmacros.h" from testsuites/support/include to app/ticker. Now after
>>>>>>>>>>>>> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
>>>>>>>>>>>>> found. When I copied it to my app/ticker directory it didn't work and I
>>>>>>>>>>>>> still have the same error.
>>>>>>>>>>>>> >> >> Would it be possible for you to paste your wscript
>>>>>>>>>>>>> somewhere (like
>>>>>>>>>>>>> >> >> gist.github.com) and share it here so that we can have
>>>>>>>>>>>>> a look and help
>>>>>>>>>>>>> >> >> you with that?
>>>>>>>>>>>>> >> >> Best regards,
>>>>>>>>>>>>> >> >> Vijay
>>>>>>>>>>>>> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>>>>>>>>>>>>> >> >> > [1/3] Compiling tasks.c
>>>>>>>>>>>>> >> >> > [2/3] Compiling init.c
>>>>>>>>>>>>> >> >> > In file included from ../../system.h:17:0,
>>>>>>>>>>>>> >> >> > from ../../init.c:15:
>>>>>>>>>>>>> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h:
>>>>>>>>>>>>> >> >> > #include <buffer_test_io.h>
>>>>>>>>>>>>> >> >> > compilation terminated.
>>>>>>>>>>>>> >> >> > from ../../tasks.c:22:
>>>>>>>>>>>>> >> >> > Build failed
>>>>>>>>>>>>> >> >> > -> task in 'ticker.exe' failed with exit status 1
>>>>>>>>>>>>> (run with -v to display more information)
>>>>>>>>>>>>> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
>>>>>>>>>>>>> >> >> >> Hi Olga,
>>>>>>>>>>>>> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
>>>>>>>>>>>>> >> >> >> > I've built the RTEMS Kernel for erc32. Then I
>>>>>>>>>>>>> https://docs.rtems.org/branches/master/user/start/app.html to
>>>>>>>>>>>>> build a "Hello World" application and it works just fine. Then I've tried
>>>>>>>>>>>>> to create another application following the steps in the tutorial.
>>>>>>>>>>>>> >> >> >> > 1. In $HOME/development/app/ I created a directory
>>>>>>>>>>>>> "ticker".
>>>>>>>>>>>>> >> >> >> > 2. cd ticker
>>>>>>>>>>>>> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>>>>>>>>>>>>> >> >> >> > chmod +x waf
>>>>>>>>>>>>> >> >> >> > git init
>>>>>>>>>>>>> >> >> >> > git submodule add git://
>>>>>>>>>>>>> git.rtems.org/rtems_waf.git rtems_waf
>>>>>>>>>>>>> >> >> >> > 4. I've copied the files "init.c", "tasks.c",
>>>>>>>>>>>>> "system.h" from testsuites/samples
>>>>>>>>>>>>> >> >> >> > 5. In the "wscript" I've changed the lines 32 and
>>>>>>>>>>>>> 34 to target = 'ticker.exe', source = ['init.c', 'tasks.c']
>>>>>>>>>>>>> >> >> >> > 6. ./waf configure
>>>>>>>>>>>>> --rtems=$HOME/development/rtems/5 --rtems-bsp=sparc/erc32
>>>>>>>>>>>>> >> >> >> > 7. and running ./waf next, I get an error. It looks
>>>>>>>>>>>>> like the file "tmacros.h", which is included in "system.h", cannot be found.
>>>>>>>>>>>>> >> >> >> You have changed the "target" and "source" parameters
>>>>>>>>>>>>> in your wscript.
>>>>>>>>>>>>> >> >> >> You'd also need to modify the "include" parameter and
>>>>>>>>>>>>> add relative
>>>>>>>>>>>>> >> >> >> path to tmacros.h. For multiple headers, you'll have
>>>>>>>>>>>>> to add the paths
>>>>>>>>>>>>> >> >> >> as a string with space-separated values or a list
>>>>>>>>>>>>> like this:
>>>>>>>>>>>>> >> >> >> `includes='./ ../ ./path/to/include/'`
>>>>>>>>>>>>> >> >> >> > What am I doing wrong? Is the way to run other
>>>>>>>>>>>>> examples exactly the same as to run a "Hello World" example?
>>>>>>>>>>>>> >> >> >> The other examples will also follow a similar wscript
>>>>>>>>>>>>> structure but
>>>>>>>>>>>>> >> >> >> hello world is the simple one with fewer includes so
>>>>>>>>>>>>> it's a good place
>>>>>>>>>>>>> >> >> >> to start if you're trying to learn how to make a
>>>>>>>>>>>>> separate project with
>>>>>>>>>>>>> >> >> >> RTEMS applications using waf.
>>>>>>>>>>>>> >> >> >> Best regards,
>>>>>>>>>>>>> >> >> >> Vijay
>>>>>>>>>>>>> >> >> >> > _______________________________________________
>>>>>>>>>>>>> >> >> >> > users mailing list
>>>>>>>>>>>>> >> >> >> > users at rtems.org
>>>>>>>>>>>>> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
>>>>>>>>>>>> www.avast.com
>>>>>>>>>>>> <#m_-356064547562217854_m_-9076596597508598725_m_7917335146911979221_m_-3453968078082772622_m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>>>>>> users mailing list
>>>>>>>>>>>> users at rtems.org
>>>>>>>>>> users mailing list
>>>>>>>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210318/89c5fd74/attachment-0001.html>
