GSoC Introduction
Joel Sherrill
joel at rtems.org
Fri May 21 13:32:52 UTC 2021
On Fri, May 21, 2021 at 7:03 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> Sir,
> I think that makes sense. I'll put some time into it and will follow
> up in our first meeting next week.
I sent an email to newlib@ and cc'ed you but you should subscribe.
Corinna said that winsup/cygwin/strsig.cc could be a good starting point
or reference. I tend to think providing the historical BSD interfaces and
the
newer POSIX ones is a good thing.
psignal() and psiginfo() would be good to provide also but the
implementation
there is strictly Cygwin specific in details. It should be possible to add
an
RTEMS implementation to the RTEMS source for these.
The other thing I forgot to mention is that when you add a prototype to
a POSIX header, you need to add a corresponding compile-only test to
testsuites/psxtests/psxhdrs. Lining up all the headers as a starting point
and picking at the methods you mentioned would be a good first step.
Hopefully one set of patches to the headers and you don't touch them
again for the rest of the summer.
> Now I'm about to jump on a
> transatlantic flight with my four-year-old (Please wish me
> luck)...Thank you again and have a great weekend!
Hope the four year old does well. That's younger than when we first
did a trip to Europe with our four children. I think the youngest was
about 10 then. I joked that they all had to be self-propelled with their
own carry on gear, no stroller, and no car seats.
--joel
> Sincerely,
> Matt
> On Thu, May 20, 2021 at 10:50 AM Joel Sherrill <joel at rtems.org> wrote:
> > On Thu, May 20, 2021 at 8:21 AM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> >> Dr. Joel,
> >> Thanks! I'd definitely like to get one or two easier ones under my
> >> belt first. Based on my initial look for what can be ported, I'd plan
> >> to start with dladdr. Sig2str and str2sig have to be re-implemented,
> >> but I think they should be fairly straightforward. Once I have those
> >> done, I'll start to tackle the others. Does that sound reasonable, or
> >> would you have a different recommendation?
> > That sounds reasonable enough. As a work pattern for adding POSIX
> > APIs, it has worked best to assume you will have patches outstanding
> > for multiple APIs at the same time. While one is being reviewed, you
> > should work on the next.Sometimes the newer ones end up getting
> > wrapped up before the first ones posted.
> > Also all the new APIs require adding prototypes to newlib POSIX
> > headers. This means tool bumps which means it would be a good idea
> > to put together a patch to update the POSIX headers which are in
> > newlib to add the new APIs in a batch. This will mean a single bump
> > of the newlib version in the RSB which has a reasonable chance of working
> > for all the additions.
> > Adding methods as needed to the headers would be a fairly easy
> > step and is a prerequisite for a number of your planned methods.
> >> Also, where can I find the master API tracking CSV file? Thanks again!
> > It is in rtems-docs
> https://git.rtems.org/rtems-docs/tree/posix-compliance/RTEMS-Standards-Compliance.csv
> > I don't recall adding the new methods yet and someone internal
> > spotted a couple of minor mistakes so it looks like I will be updating
> > it soon.
> >> Sincerely,
> >> Matt
> >> On Wed, May 19, 2021 at 7:11 PM Joel Sherrill <joel at rtems.org> wrote:
> >> > On Wed, May 19, 2021 at 9:09 AM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> >> >> Hello RTEMS Community,
> >> >> My name is Matt Joyce and it is a great honor for me to join you as a
> >> >> 2021 GSoC student developer! I'm a former active-duty US Army
> infantry
> >> >> officer now serving part-time in the reserves. Since 2019 I've been
> >> >> back in school pursuing a BS in Computer Science remotely at Oregon
> >> >> State while based with my family in Berlin, Germany.
> >> >> I see that there is a large group of RTEMS developers/users in
> >> >> Germany, so one day I hope to be able to meet some of you in person,
> >> >> too!
> >> > Hopefully this will be a fun summer for you.
> >> >> My project focuses on POSIX compliance. I plan to add multiple new
> >> >> methods not currently supported by RTEMS with the intent to improve
> >> >> application portability.
> https://summerofcode.withgoogle.com/projects/?sp-search=Matthew%20Joyce#6686502693634048
> >> >> With your guidance, I am excited to dive in and put what I've been
> >> >> learning to work and make my first real-world contributions to the
> >> >> greater good.
> >> > Any idea which method(s) you want to tackle first?
> >> > --joel
> >> >> Thank you very much for this opportunity! I look forward to working
> with you.
> >> >> Sincerely,
> >> >> Matt
> >> >> _______________________________________________
> >> >> users mailing list
> >> >> users at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210521/2d223518/attachment.html>
