Statically allocated build
Петр Борисенко
peter at awsmtek.com
Tue Sep 28 11:52:23 UTC 2021
No. there is no filesystem.
The application is build upon the stm32f4 bsp, and linker script's kept
unchanged.
On Tue, Sep 28, 2021, 8:28 AM Sebastian Huber <
> Hello,
> On 24/09/2021 20:08, Петр Борисенко wrote:
> > Hello everyone!
> > I am currently creating a aerial robot application upon the arm/stm32f4
> bsp
> > (extending it, possibly will contribute soon)
> > I have just moved from RTEMS5 to RTEMS6 and have a few questions.
> > 1. I don't understand how to build a system fully statically allocated.
> For
> > safety reasons I shouldn't use neither heap for the system objects nor
> > dynamic loading.
> if you don't use the unlimited objects option, then the Classic API
> objects are statically allocated in RTEMS 6. You can construct tasks and
> message queues with user-provided storage:
> https://docs.rtems.org/branches/master/c-user/task/directives.html#rtems-task-construct
> https://docs.rtems.org/branches/master/c-user/message/directives.html#rtems-message-queue-construct
> The POSIX and C++ synchronization objects use user-provided storage.
> > 2. I have just noticed that `__usrenv.c` has been compiled into my
> > application. I don't understand how to disable it.
> I would look at the linker map file. You probably use a file system.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
