Windows as a RTEMS dev environment
Matthew J Fletcher
amimjf at gmail.com
Fri Apr 15 12:38:39 UTC 2022
ok, https://devel.rtems.org/ticket/4547
Bit of a mess. Lets try again with Ubuntu, after that AIX !
On Fri, 15 Apr 2022 at 13:14, Matthew J Fletcher <amimjf at gmail.com> wrote:
> As an update with Mingw64 i had to manually create x86_64-w64-mingw32-g++
> and x86_64-w64-mingw32-gcc (just copy & paste of g++ and gcc), now it can
> find all the tools, no idea how the tools RSB is looking for would be
> created.
> Oddly even with Mingw64 the "convert-dtsv0-lexer.l:27:10: fatal error:
> fnmatch.h: No such file or directory" issue is still there, and its not
> actually present,.. will probably just end up install all of Mingw
> Looking at the RSB logs, it looks like the include paths generated are
> pretty messed up "
> -I/c/Users/MatthewFletcher/play/src/rsb/rtems/build/tmp/sb-197609/6s/c/Users/MatthewFletcher/play/rtems/6/include
> On Fri, 15 Apr 2022 at 12:29, Matthew J Fletcher <amimjf at gmail.com> wrote:
>> Hi,
>> To make Joel happy with a patch i've been trying to setup a Windows VM as
>> a build environment, the process seems to have a few issues.
>> 1) If your username/profile has a space in it the scripts dont all
>> encapsulate with quotes so break in various ways. Ok, so, created a new
>> user to get around that.
>> 2) Getting a native build environment msys2, mingw64, etc setup seems
>> pretty random. Tried mingw64 first but makeinfo and some other tools not
>> available, ok, so moved to msys2. Dependency checks now pass but rsb
>> builder fails on first package DTC.
>> convert-dtsv0-lexer.l:27:10: fatal error: fnmatch.h: No such file or
>> directory
>> Its clearly present at C:\msys64\usr\include\fnmatch.h
>> RSB looks to have issues, not surprising given the million possible
>> windows setups.
>> Does anyone have a known working setup on Windows ?
>> regards
>> Matthew J Fletcher
> regards
> Matthew J Fletcher
regards
Matthew J Fletcher
