Windows as a RTEMS dev environment
Joel Sherrill
joel at rtems.org
Fri Apr 15 20:07:16 UTC 2022
On Fri, Apr 15, 2022 at 1:21 PM zhengxiaojun <jameszxj at gmail.com> wrote:
> Hi,
> >ok, https://devel.rtems.org/ticket/4547
> Mingw64 has a pre-compiled dtc package, you can bypass the compilation.
That's good to know. That means we have two possible solutions:
(1) Disable dtc in RSB for mingw64. Possible downside on version
incompatibility
(2) Figure out what they did to build it and mirror that patch into the RSB
recipe.
https://packages.msys2.org/package/dtc?repo=msys&variant=x86_64 appears to
be
the package so perhaps the answer is in there.
An easy workaround is to comment out dtc in rtems-default.bset and load the
mingw package.
Thanks for the info.
--joel
> >Bit of a mess. Lets try again with Ubuntu, after that AIX !
> >On Fri, 15 Apr 2022 at 13:14, Matthew J Fletcher <amimjf at gmail.com>
> wrote:
> >> As an update with Mingw64 i had to manually create
> x86_64-w64-mingw32-g++
> >> and x86_64-w64-mingw32-gcc (just copy & paste of g++ and
> gcc), now it can
> >> find all the tools, no idea how the tools RSB is looking for
> would be
> >> created.
> >> Oddly even with Mingw64 the "convert-dtsv0-lexer.l:27:10: fatal
> error:
> >> fnmatch.h: No such file or directory" issue is still there, and
> its not
> >> actually present,.. will probably just end up install all of Mingw
> >> Looking at the RSB logs, it looks like the include paths
> generated are
> >> pretty messed up "
> -I/c/Users/MatthewFletcher/play/src/rsb/rtems/build/tmp/sb-197609/6s/c/Users/MatthewFletcher/play/rtems/6/include
> >> On Fri, 15 Apr 2022 at 12:29, Matthew J Fletcher <
> amimjf at gmail.com> wrote:
> >>> Hi,
> >>> To make Joel happy with a patch i've been trying to setup a
> Windows VM as
> >>> a build environment, the process seems to have a few issues.
> >>> 1) If your username/profile has a space in it the scripts
> dont all
> >>> encapsulate with quotes so break in various ways. Ok, so,
> created a new
> >>> user to get around that.
> >>> 2) Getting a native build environment msys2, mingw64, etc
> setup seems
> >>> pretty random. Tried mingw64 first but makeinfo and some
> other tools not
> >>> available, ok, so moved to msys2. Dependency checks now pass
> but rsb
> >>> builder fails on first package DTC.
> >>> convert-dtsv0-lexer.l:27:10: fatal error: fnmatch.h: No such
> file or
> >>> directory
> >>> Its clearly present at C:\msys64\usr\include\fnmatch.h
> >>> RSB looks to have issues, not surprising given the million
> possible
> >>> windows setups.
> >>> Does anyone have a known working setup on Windows ?
> >>> regards
> >>> Matthew J Fletcher
> >> regards
> >> Matthew J Fletcher
> >regards
> >Matthew J Fletcher
> >_______________________________________________
> >users mailing list
> >users at rtems.org
> >http://lists.rtems.org/mailman/listinfo/users</amimjf@gmail.com></
> users mailing list
> users at rtems.org
