Want to add RISC-V-based PolarFire SoC support to RTEMS
Padmarao.Begari at microchip.com
Mon Aug 29 08:51:19 UTC 2022
Hi Sebastian,
Agree with You,
> return (uint32_t) mhartid - RISCV_MHARTID_OFFSET;
Want to add "*_MHARTID_OFFSET" a new option in cpu
with "optboothartid.yml".
which name can we choose for this, below are options:
1. "RTEMS_BOOT_HARTID"
2. "RTEMS_RISCV_BOOT_HARTID"
3. "RISCV_MHARTID_OFFSET"
4. "RTEMS_RISCV_MHARTID_OFFSET"
Regards
Padmarao
On Mon, 2022-08-29 at 09:30 +0200, Sebastian Huber wrote:
> Hello Padmarao,
> On 26/08/2022 13:37, Padmarao.Begari at microchip.com wrote:
> > The boot HARTID configurable is Ok but I am thinking about SMP.
> > The PolarFire SoC has 4 U54's with hartid 1,2,3,4 but the SMP
> > starts with cpu number '0' to MAX cpu number then the PolarFire
> > SoC U54's hartid number should become 0,1,2,3 to run the SMP.
> the numbers returned by
> static inline uint32_t _CPU_SMP_Get_current_processor( void )
> unsigned long mhartid;
> __asm__ volatile (
> ".option push\n"
> ".option arch, +zicsr\n"
> "csrr %0, mhartid\n"
> ".option pop" :
> "=&r" ( mhartid )
> return (uint32_t) mhartid;
> must be in the range 0, ..., CPU count - 1. For your chip you need
> something like
> __asm__ volatile (
> ".option push\n"
> ".option pop" :
> "=&r" ( mhartid )
> return (uint32_t) mhartid + RISCV_MHARTID_OFFSET;
> The RISCV_MHARTID_OFFSET could be a new CPU option which has
> BSP-dependent default values. It would be the first CPU option in
> RTEMS
> with BSP-dependent default values.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
