Want to add RISC-V-based PolarFire SoC support to RTEMS
Sebastian Huber
Mon Aug 29 07:30:23 UTC 2022
Hello Padmarao,
On 26/08/2022 13:37, Padmarao.Begari at microchip.com wrote:
> The boot HARTID configurable is Ok but I am thinking about SMP.
> The PolarFire SoC has 4 U54's with hartid 1,2,3,4 but the SMP
> starts with cpu number '0' to MAX cpu number then the PolarFire
> SoC U54's hartid number should become 0,1,2,3 to run the SMP.
the numbers returned by
static inline uint32_t _CPU_SMP_Get_current_processor( void )
unsigned long mhartid;
__asm__ volatile (
".option push\n"
".option arch, +zicsr\n"
"csrr %0, mhartid\n"
".option pop" :
"=&r" ( mhartid )
return (uint32_t) mhartid;
must be in the range 0, ..., CPU count - 1. For your chip you need
something like
__asm__ volatile (
".option push\n"
".option pop" :
"=&r" ( mhartid )
return (uint32_t) mhartid + RISCV_MHARTID_OFFSET;
The RISCV_MHARTID_OFFSET could be a new CPU option which has
BSP-dependent default values. It would be the first CPU option in RTEMS
with BSP-dependent default values.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
