Testing SMP Configuration with rtems-test
Jerzy J
yuralogplus at gmail.com
Sat Feb 19 13:26:10 UTC 2022
Hi,
I've been trying to get some coverage reports on my tests. I'm using RTEMS
6 and gr712rc/leon3 bsps.
Normally I run my tests using:
`./sparc-rtems6-sis -leon3 -r s -m 4
$HOME/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe`
, where I can specify `-m 4`.
However when using rtems-test:
`./rtems-test --rtems-tools=$HOME/RTEMS/rtems/6 --log=log_leon3_sis
--rtems-bsp=leon3-sis-cov --coverage
~/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe
My tests fail, since as I can see in the log it runs:
`=> exe: /home/yoman/RTEMS/rtems/6/bin/sparc-rtems6-sis -leon3 -nouartrx
-r -tlim 200 s -cov
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe`
resulting in only 1 cpu online.
Is there a way I can pass `-m 4` into rtems-test or is there some extra
configuration step I'm probably not aware of that handles this?
My 'config.ini' file:
`[sparc/gr712rc]
RTEMS_SMP = True
BUILD_TESTS = True`
Thank you in advance and all the best!
Jerzy
