RTEMS_FATAL_SOURCE_EXCEPTION during startup
Sat Jan 1 16:09:23 UTC 2022
Assuming it is compiled correctly, printing this early should be via
printk().
Can you attach gdb and just walk through the BSP initialisation?
--joel
On Sat, Jan 1, 2022, 2:08 AM <groups at chichak.ca> wrote:
> (sorry, I accidentally sent this to the dev list instead of users. too
> much cheer)
> It’s bombing in printf. It’s so early that the stack hasn’t been set up
> yet, and it’s found an error and it’s trying to poot a message out on the
> console, which is also not set up yet.
> Umm, what could be wrong? Lemme think… (I’ve worked wth this bsp in
> RTEMS4.11, and a version in RTEMS5)
> I had problems with that BSP blowing up just like this because portions of
> it weren’t compiled with the proper instruction set, and when the startup
> code called memset (I think), it would call memset in newlib/libc that was
> compiled for the wrong architecture, do the wrong thing, end up in printf
> and die a horrible death.
> Let’s see if I can find the thread on Discord…
> around August 19/2021
> run:
> rtems-exeinfo -O blah.exe
> and make sure that all of the functions have the same architecture
> specified. Mine had a mix of -mcpu=cortex-m4 and -mcpu=arm7tdmi which are
> incompatible.
> Andrei Chichak
> (from The Great White North)
> > On 2021-December-31, at 18:48, Петр Борисенко <peter at awsmtek.com> wrote:
> > Hello and Happy new year!
> > I am getting an error during startup:
> > Catching it in _ARM_Exception_default.
> > The bsp is `arm/stm32f4`.
> > Here is contains of CPU_Exception_frame:
> > register_r0 uint32_t 0x80139bc
> > register_r1 uint32_t 0
> > register_r2 uint32_t 0
> > register_r3 uint32_t 76
> > register_r4 uint32_t 0
> > register_r5 uint32_t 0
> > register_r6 uint32_t 0
> > register_r7 uint32_t 0
> > register_r8 uint32_t 0
> > register_r9 uint32_t 0
> > register_r10 uint32_t 0
> > register_r11 uint32_t 0
> > register_r12 uint32_t 0
> > register_sp uint32_t 536909088
> > register_lr void * 0x80001c3 <bsp_start_hook_0_done+4>
> > register_pc void * 0x8013f08 <_svfprintf_r+8152>
> > register_xpsr uint32_t 16777216
> > vector uint32_t 3
> > vfp_context const ARM_VFP_context * 0x0
> > reserved_for_stack_alignment uint32_t 3522771716
> > &Console_Port_Minor rtems_device_minor_number * 0x20006988
> > <Console_Port_Minor>
> > *&Console_Port_Minor rtems_device_minor_number 1363452156
> > What could it be? Any common reasons? Or what additional info should I
> > provide?
> > Also it would be really appreciated if someone will help me export/build
> > bsp as a debuggable source tree.
> > Best regards.
> > Peter Borisenko
> > Awesome Technologies, Ltd.
> > http://awsmtek.com
> > hardware at awsmtek.com
> > +79062165482
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> devel mailing list
> devel at rtems.org
> users mailing list
> users at rtems.org
