RTEMS_FATAL_SOURCE_EXCEPTION during startup
Петр Борисенко peter at awsmtek.com
Sat Jan 1 20:56:54 UTC 2022
I didn't print anything explisitly.
Here is call stack:
Thread #1 (Suspended : Signal : SIGINT:Interrupt)
output_char() at console-config.c:104 0x8007132
rtems_putc() at rtems_putc.c:31 0x800f038
_IO_Vprintf() at iovprintf.c:133 0x800b8b4
vprintk() at vprintk.c:31 0x8009aa0
printk() at printk.c:40 0x800794e
bsp_fatal_extension() at bspfatal-default.c:26 0x8006ea2
_User_extensions_Iterate() at userextiterate.c:181 0x800e686
_User_extensions_Fatal() at userextimpl.h:446 0x800b856
_Terminate() at interr.c:38 0x800b856
rtems_fatal() at fatal.h:158 0x80103a6
_ARM_Exception_default() at arm-exception-default.c:24 0x80103a6
<signal handler called>() at 0xfffffff9
0x0
Best regards.
Peter Borisenko
Awesome Technologies, Ltd.
http://awsmtek.com
hardware at awsmtek.com
+79062165482
On Sat, Jan 1, 2022 at 7:09 PM Joel Sherrill <joel at rtems.org> wrote:
> Assuming it is compiled correctly, printing this early should be via
> printk().
> Can you attach gdb and just walk through the BSP initialisation?
> --joel
> On Sat, Jan 1, 2022, 2:08 AM <groups at chichak.ca> wrote:
> > (sorry, I accidentally sent this to the dev list instead of users. too
> > much cheer)
> > It’s bombing in printf. It’s so early that the stack hasn’t been set up
> > yet, and it’s found an error and it’s trying to poot a message out on the
> > console, which is also not set up yet.
> > Umm, what could be wrong? Lemme think… (I’ve worked wth this bsp in
> > RTEMS4.11, and a version in RTEMS5)
> > I had problems with that BSP blowing up just like this because portions
> of
> > it weren’t compiled with the proper instruction set, and when the startup
> > code called memset (I think), it would call memset in newlib/libc that
> was
> > compiled for the wrong architecture, do the wrong thing, end up in printf
> > and die a horrible death.
> > Let’s see if I can find the thread on Discord…
> > around August 19/2021
> > run:
> > rtems-exeinfo -O blah.exe
> > and make sure that all of the functions have the same architecture
> > specified. Mine had a mix of -mcpu=cortex-m4 and -mcpu=arm7tdmi which are
> > incompatible.
> > Andrei Chichak
> > (from The Great White North)
> > > On 2021-December-31, at 18:48, Петр Борисенко <peter at awsmtek.com>
> wrote:
> > > Hello and Happy new year!
> > > I am getting an error during startup:
> > > Catching it in _ARM_Exception_default.
> > > The bsp is `arm/stm32f4`.
> > > Here is contains of CPU_Exception_frame:
> > > register_r0 uint32_t 0x80139bc
> > > register_r1 uint32_t 0
> > > register_r2 uint32_t 0
> > > register_r3 uint32_t 76
> > > register_r4 uint32_t 0
> > > register_r5 uint32_t 0
> > > register_r6 uint32_t 0
> > > register_r7 uint32_t 0
> > > register_r8 uint32_t 0
> > > register_r9 uint32_t 0
> > > register_r10 uint32_t 0
> > > register_r11 uint32_t 0
> > > register_r12 uint32_t 0
> > > register_sp uint32_t 536909088
> > > register_lr void * 0x80001c3 <bsp_start_hook_0_done+4>
> > > register_pc void * 0x8013f08 <_svfprintf_r+8152>
> > > register_xpsr uint32_t 16777216
> > > vector uint32_t 3
> > > vfp_context const ARM_VFP_context * 0x0
> > > reserved_for_stack_alignment uint32_t 3522771716
> > > &Console_Port_Minor rtems_device_minor_number * 0x20006988
> > > <Console_Port_Minor>
> > > *&Console_Port_Minor rtems_device_minor_number 1363452156
> > > What could it be? Any common reasons? Or what additional info should I
> > > provide?
> > > Also it would be really appreciated if someone will help me
> export/build
> > > bsp as a debuggable source tree.
> > > Best regards.
> > > Peter Borisenko
> > > http://awsmtek.com
> > > +79062165482
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> > devel mailing list
> > devel at rtems.org
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
