How can I add LDFLAGS for bsp build?
DAVE ERICKSON
daveerickson at shaw.ca
Fri Jul 22 15:12:31 UTC 2022
Thanks for stepping on my point, Joel. :)
( I attended the RTEMS Open course instructed by Joel many years ago... )
Joel's comments on
CFLAGS += -Og -g -Wall
CXXFLAGS += -Og -g -Wall
will NOT solve your gcc "can't find library problem" since these are tangential to your problem and are compiler flags. Compiler flags don't affect linking which is the stage where gcc/ar/ld programs create the code archive.
If you want to express exactly which library to use then specify in the LDFLAGS environment variable in the folder where gcc is configured to "build from" in bsps/arm/tms570/config/xxx.cfg
LDFLAGS += ~/ ...rest of explicit path... /arm-rtems5/lib/libm.a
(NOTICE NO FLAG PREFIX ON EXPLICIT PATH)
Will instruct gcc/ar/ld to do exactly what you want, which is include EXACTLY that library at EXACTLY that location.
The explicit library path can be used to check and see if it's a location problem before a library internals problem.
nm -D or nm to find the missing symbol inside a library.
BTW RTEMS uses GNU autotools differently in that it configures in one folder/directory and the builds targets into another folder is a very rare way of using autotools. I know this because I have downloaded and reviewed over 5000 open source projects for my new book.
Most GNU autotools projects configure IN THE FOLDER that they want to compile and archive source code. That's one reason why the problems of diagnosing RTEMS build configurations are harder.
Setting explicit file locations with absolute directories is a way to workaround the problems.
Cheers!
Daemondave on github
Check out my new book Untrapped Value on LeanPub: https://leanpub.com/untrappedvalue
To: "DAVE ERICKSON" <daveerickson at shaw.ca>
Cc: "Y. HB" <sprhawk at gmail.com>, "rtems-users at rtems.org" <users at rtems.org>
Sent: Friday, July 22, 2022 8:42:49 AM
Subject: Re: How can I add LDFLAGS for bsp build?
This is an application matter and it all depends on what build system you are using.
If your build system is make, then something like this will probably work.
LDFLAGS += -lm
You may also want to ensure that the CFLAGS has the desired optimization, debug, and warning levels selected:
If using waf, cmake, etc, etc, you ultimately want to produce the same invocations of gcc but the mechanics are different.
--joel
On Fri, Jul 22, 2022 at 9:09 AM DAVE ERICKSON < [ mailto:daveerickson at shaw.ca | daveerickson at shaw.ca ] > wrote:
Hi Y.HB
LDFLAGS sets both the library kind to include in the archive build but it also uses the -L flags to know where to look for it. The -lm can mean the libm.a. libm.so [ http://libm.la/ | libm.la ] so it searches the LD_LIBRARY_PATH environment variable to find one that fits. If you want expressly to include the libm.a you should specify it instead of -lm. The first thing I recommend is find the symbols inside the Makefile configured for the . Look for the LDFLAGS and then your LD_LIBRARY_PATH to see if it matches where that arm-rtems5/lib/libm.a is.
You can even use the flag argument: arm-rtems5/lib/libm.a or ./arm-rtems5/lib/libm.a to express the precise library and location to use.
This is one important distinction that many people confuse about how automake and autoconf work: There is no "internal logic" in the autotools way of creating recipes for Makefiles. m4 is used for pattern processing. You must express what you want it to make, it won't go looking anywhere else than what is specified.
It's not cmake, scons, or raw make. GNU Autotools creates recipe files, like config.status, that just hold environmental variables.
DaemonDave on github.
From: "Y. HB" < [ mailto:sprhawk at gmail.com | sprhawk at gmail.com ] >
To: " [ mailto:rtems-users at rtems.org | rtems-users at rtems.org ] " < [ mailto:users at rtems.org | users at rtems.org ] >
Sent: Friday, July 22, 2022 12:11:38 AM
I added -lm in LDFLAGS in my custom bsps/arm/tms570/config/xxx.cfg
the flag is added to compiling arguments, but it still reported undefined reference to 'floor', but I see there is floor symbols in the arm-rtems5/lib/libm.a
Why is it?
Thanks
On Fri, Jul 22, 2022 at 1:43 PM Y. HB < [ mailto:sprhawk at gmail.com | sprhawk at gmail.com ] > wrote:
BQ_BEGIN
Hello
I'm working on a custom tms570 bsp upon RTEMS 5.1, but it depends on math lib (-lm), how can I add this flag to the bsp build?
Shall I add LDFLAGS="-lm" during configure or shall I change some variables in c/src/lib/libbsp/arm/xxxx/Makefile.am?
Thanks
users mailing list
[ http://lists.rtems.org/mailman/listinfo/users | http://lists.rtems.org/mailman/listinfo/users ]
users mailing list
BQ_END
URL: <http://lists.rtems.org/pipermail/users/attachments/20220722/784ced76/attachment-0001.htm>
