Try to load and run RTEMS Image on Cora-z7-10
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Jun 1 13:30:14 UTC 2022
Hi Alan,
Thanks for the feedback. Did you also use the Ethernet of the beagleboneblack in your demo. I can't see which if is implemented in the BSP.
Danke Heinz
> On 31. May 2022, at 14:43, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> If it helps, I have a demo where I built and ran RTEMS 6 with libbsd on the beaglebone black in January. I used specific commits from the repositories in an effort to make it reproducible, so if there was a regression that may help. My build used -O linux when creating the u-boot image file.
> The repo is here:
> https://github.com/alanc98/rtems-cfs-demo
> I still have the board setup. As soon as I have time, I can build a new toolchain and BSP to see if it still works.
> Alan
