Try to load and run RTEMS Image on Cora-z7-10
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Jun 1 15:14:09 UTC 2022
I can add something directly. I found in your example (rki) how you talk to the network device.
I have implemented it in a similar way.
Unfortunately, I can't even get to the point.
The programme breaks off in rtems_bsd_initialize() at mi_startup()
***** RTEMS Version: rtems-5.1.0 (ARM/ARMv4/beagleboneblack) *****
***** Initializing network (libbsd, dhcpcd) *****
 create directory /etc
create timer ...
mutex init ...
mi startup ...
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0   = 0x00000000 R8  = 0x00000000
R1   = 0x802ec93c R9  = 0x00000000
R2   = 0x00000007 R10 = 0x00000064
R3   = 0x006e6573 R11 = 0x8052e7e0
R4   = 0x00000007 R12 = 0x01010101
R5   = 0xfffffff7 SP  = 0x80553f30
R6   = 0x802ec93c LR  = 0x8022fcb4
R7   = 0x00000000 PC  = 0x8022ef68
CPSR = 0x00000113 VEC = 0x00000004
RTEMS version: 5.1.0
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1, Newlib 7947581)
executing thread ID: 0x08b010001
executing thread name:
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 1. Jun 2022, at 15:30, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi Alan,
> Thanks for the feedback. Did you also use the Ethernet of the beagleboneblack in your demo. I can't see which if is implemented in the BSP.
> Danke Heinz
>> On 31. May 2022, at 14:43, Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> If it helps, I have a demo where I built and ran RTEMS 6 with libbsd on the beaglebone black in January. I used specific commits from the repositories in an effort to make it reproducible, so if there was a regression that may help. My build used -O linux when creating the u-boot image file.
>> The repo is here:
>> https://github.com/alanc98/rtems-cfs-demo
>> I still have the board setup. As soon as I have time, I can build a new toolchain and BSP to see if it still works.
>> Alan
> users mailing list
> users at rtems.org
