Split BSP in RTEMS 4.11 - autotools newbie question
Sebastian Huber
Mon Mar 14 14:38:11 UTC 2022
On 14/03/2022 15:12, dsa93 wrote:
> I tried to change it to "rtems-c-src-lib-libbsp-arm-samrh71" (same as bsp root folder), but doing this kind of autotools voodo didnt helped. The result is still the same: Make does not see any target inside BSP folder. I guess I will continue work on two GIT branches and maybe colleagues will fix it some day :)
I would also recommend you try it with RTEMS 6 which uses a new build
system.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
