Split BSP in RTEMS 4.11 - autotools newbie question
dsa93 dsa93 at pm.me
Mon Mar 14 14:12:55 UTC 2022
I tried once again and it does not work for me
I was searching for an "atsam" phrase in buildsystem to find if this phrase isnt hardcoded somewhere. I found for example this:
AC_INIT([rtems-c-src-lib-libbsp-arm-atsam],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
at the top of:
RTEMS-OS/c/src/lib/libbsp/arm/atsam/configure.ac
I tried to change it to "rtems-c-src-lib-libbsp-arm-samrh71" (same as bsp root folder), but doing this kind of autotools voodo didnt helped. The result is still the same: Make does not see any target inside BSP folder. I guess I will continue work on two GIT branches and maybe colleagues will fix it some day :)
Best regards
dsa
------- Original Message -------
poniedziałek, 14 marca 2022 14:10, Joel Sherrill <joel at rtems.org> napisał(a):
> On Mon, Mar 14, 2022 at 7:37 AM Dariusz.sabala <dsa93 at pm.me> wrote:
>> Hello
>> I am developing SAMRH71 BSP in RTEMS 4.11, I started editing atsam BSP and accomplished some success, but the decision was made to support both BSP (atsam and samrh71) in separate folders. I reverted my changes, copied and renamed atsam folder to samrh71 and tried to build this renamed BSP, but unfortunately nothing is being built - make just enters the folder and leaves it with no artifact build
>> make[1]: Entering directory '/home/dsa/projects/p1/repo/rtems/samrh71/arm-rtems4.11/c'
>> Making all in .
>> make[2]: Entering directory '/home/dsa/projects/p1/repo/rtems/samrh71/arm-rtems4.11/c'
>> make[2]: Nothing to be done for 'all-am'.
>> Can you give me advice on what and where to change in the buildsystem to make it build? Honestly I am cmake kid :) and knowing that autotools is no longer supported in the newest RTEMS does not encourage learning this powerful but complex tool.
> Assuming there aren't any mistakes lurking. :)
> From the top directory:
> bootstrap -c
> bootstrap -p
> bootstrap
> When you add, move, and delete directories, it is possible that the generated fragments which include lists of BSPs could get out of sync.
> Overall, I'd recommend you move to 6.
> --joel
>> Best regards
>> dsa
>> users mailing list
>> users at rtems.org
