Fwd: RTEMS 5 on mcp750 fails
    Miroslaw Dach
    miroslaw.dach at gmail.com
    Fri May 20 20:55:03 UTC 2022
Hi Chris,
Thank you very much for your expertise and attached links which are very
helpful.
As regards the INTERNAL_ERROR_TOO_LITTLE_WORKSPACE error message:
Is it  possible to determine with some debug information what is the
foreseen by RTEMS WORKSPACE size?
Best Regards
Mirek
śr., 18 maj 2022 o 00:53 Chris Johns <chrisj at rtems.org> napisał(a):
> On 18/5/2022 9:36 am, Miroslaw Dach wrote:
> > Dear RTEMS Users and Developers,
> > I have built RTEMS 5 with EPICS 7 and tried to boot my application on
> > mcp750 cPCI board.
> > The first thing that I have encountered is that the boot file is in the
> elf
> > format so I have
> > converted it to the binary one.:
> > powerpc-rtems5-objcopy -I elf32-powerpc -O binary myApp.boot
> myApp.boot.bin
> We removed the various post-link hooks.
> > So far so good
> > Next, I booted the system with my app and it fails in the  *bsp_early*
> > function in
> > bsps/powerpc/motorola_powerpc/start/bspstart.c
> > The boot sequence:
> > Network Boot File load in progress... To abort hit <BREAK>
> > Bytes Received =&1270208, Bytes Loaded =&1270208
> > Bytes/Second   =&635104, Elapsed Time =2 Second(s)
> > Residual-Data Located at: $01F88000
> > Model: (e2)
> > Serial: MOT0000000
> > Processor/Bus frequencies (Hz): 366680480/66671508
> > Time Base Divisor: 4000
> > Memory Size: 2000000
> > Residual: 1f88000 (length 27148)
> > PCI: Probing PCI hardware
> > RTEMS 5.0.0/PPC load:
> > Uncompressing the kernel...
> > done
> > Now booting...
> > Welcome to rtems-5.0.0 (PowerPC/Generic (classic FPU)/mcp750) on Mesquite
> > cPCI (MCP750)
> > idreg 0 = 0x1208029271
> > OpenPIC found at 0xc1000000.
> > pci : Configuring interrupt routing for 'Mesquite cPCI (MCP750)'
> > pci : No bridge from bus 0 towards root found
> > pci : Device 1:0x0b:0 routed to interrupt_line 27
> > pci : Device 1:0x0d:0 routed to interrupt_line 25
> > Cleared PCI errors: pci_stat was 0x2280
> > OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0x3238002688
> > OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
> > OpenPIC timer frequency is 8333848 Hz
> This all looks OK.
> > *** FATAL ***
> > fatal source: 0 (INTERNAL_ERROR_CORE)
> > fatal code: 2 (INTERNAL_ERROR_TOO_LITTLE_WORKSPACE)
> > RTEMS version: 5.0.0.fc89cc76804499eba3f3bc4097b795a84f07571a-modified
> > RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6225eadda1de), Newlib
> 7947581)
> > executing thread is NULL
> > My application in the binary format uncompressed with stripped symbols
> is a
> > 2.3M + 501K bootloader so I do not think that it
> > is an issue with the WORKSPACE? The mcp750 has 32MB of RAM.
> > How to detect what is the real cause of
> > Would it be the problem with the linker script ppcboot.lds?
> I do not think so. I suggest you check the Classic API Guide here:
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/intro.html#sizing-the-rtems-workspace
> The accounting of memory is better and this means the extra space needed
> may
> need to be adjusted. I am not sure where in EPCIS this is controlled and
> if it
> can be overridden in your local configuration.
> RTEMS 5 has a unified workspace and heap. This means the heap and
> workspace can
> use memory until it is all used. The benefit is not need to manage the
> workspace
> size statically:
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/general.html#configure-unified-work-areas
> Chris
