Fwd: RTEMS 5 on mcp750 fails
Joel Sherrill
joel at rtems.org
Fri May 20 22:21:30 UTC 2022
On Fri, May 20, 2022 at 3:55 PM Miroslaw Dach <miroslaw.dach at gmail.com>
wrote:
> Hi Chris,
> Thank you very much for your expertise and attached links which are very
> helpful.
> As regards the INTERNAL_ERROR_TOO_LITTLE_WORKSPACE error message:
> Is it possible to determine with some debug information what is the
> foreseen by RTEMS WORKSPACE size?
This CONFIGURE_MEMORY_OVERHEAD is there as a mechanism to toss
extra memory at the workspace in case confdefs.h makes a mistake. I think
this
is more likely to be something else like a misconfigured system. But adding
this
to your RTEMS configuration with some chunk of memory like 128K might
allow this to proceed. But if it is a memory allocation error in the BSP
like
not assigning memory right to RTEMS, this won't fix it. See:
https://docs.rtems.org/branches/master/c-user/config/general.html#configure-memory-overhead
Chris has touched one of the boards in the motorola_powerpc family
more recently than I have. I would think this would work unless something
is off in the EPICS configuration of RTEMS. There was a discussion of the
EPICS RTEMS configuration with Till recently on tech-talk and I thought
it looked ok.
--joel
> Best Regards
> Mirek
> śr., 18 maj 2022 o 00:53 Chris Johns <chrisj at rtems.org> napisał(a):
> > On 18/5/2022 9:36 am, Miroslaw Dach wrote:
> > > Dear RTEMS Users and Developers,
> > > I have built RTEMS 5 with EPICS 7 and tried to boot my application on
> > > mcp750 cPCI board.
> > > The first thing that I have encountered is that the boot file is in the
> > elf
> > > format so I have
> > > converted it to the binary one.:
> > > powerpc-rtems5-objcopy -I elf32-powerpc -O binary myApp.boot
> > myApp.boot.bin
> > We removed the various post-link hooks.
> > > So far so good
> > > Next, I booted the system with my app and it fails in the *bsp_early*
> > > function in
> > > bsps/powerpc/motorola_powerpc/start/bspstart.c
> > > The boot sequence:
> > > Network Boot File load in progress... To abort hit <BREAK>
> > > Bytes Received =&1270208, Bytes Loaded =&1270208
> > > Bytes/Second =&635104, Elapsed Time =2 Second(s)
> > > Residual-Data Located at: $01F88000
> > > Model: (e2)
> > > Serial: MOT0000000
> > > Processor/Bus frequencies (Hz): 366680480/66671508
> > > Time Base Divisor: 4000
> > > Memory Size: 2000000
> > > Residual: 1f88000 (length 27148)
> > > PCI: Probing PCI hardware
> > > RTEMS 5.0.0/PPC load:
> > > Uncompressing the kernel...
> > > done
> > > Now booting...
> > > Welcome to rtems-5.0.0 (PowerPC/Generic (classic FPU)/mcp750) on
> Mesquite
> > > cPCI (MCP750)
> > > idreg 0 = 0x1208029271
> > > OpenPIC found at 0xc1000000.
> > > pci : Configuring interrupt routing for 'Mesquite cPCI (MCP750)'
> > > pci : No bridge from bus 0 towards root found
> > > pci : Device 1:0x0b:0 routed to interrupt_line 27
> > > pci : Device 1:0x0d:0 routed to interrupt_line 25
> > > Cleared PCI errors: pci_stat was 0x2280
> > > OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0x3238002688
> > > OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
> > > OpenPIC timer frequency is 8333848 Hz
> > This all looks OK.
> > > *** FATAL ***
> > > fatal source: 0 (INTERNAL_ERROR_CORE)
> > > fatal code: 2 (INTERNAL_ERROR_TOO_LITTLE_WORKSPACE)
> > > RTEMS version: 5.0.0.fc89cc76804499eba3f3bc4097b795a84f07571a-modified
> > > RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6225eadda1de), Newlib
> > 7947581)
> > > executing thread is NULL
> > > My application in the binary format uncompressed with stripped symbols
> > is a
> > > 2.3M + 501K bootloader so I do not think that it
> > > is an issue with the WORKSPACE? The mcp750 has 32MB of RAM.
> > > How to detect what is the real cause of
> > > Would it be the problem with the linker script ppcboot.lds?
> > I do not think so. I suggest you check the Classic API Guide here:
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/intro.html#sizing-the-rtems-workspace
> > The accounting of memory is better and this means the extra space needed
> > may
> > need to be adjusted. I am not sure where in EPCIS this is controlled and
> > if it
> > can be overridden in your local configuration.
> > RTEMS 5 has a unified workspace and heap. This means the heap and
> > workspace can
> > use memory until it is all used. The benefit is not need to manage the
> > workspace
> > size statically:
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/general.html#configure-unified-work-areas
> > Chris
> users mailing list
> users at rtems.org
