Building newly for 6/rtems-arm blows on compiling iOS_failure.cc
Sebastian Huber
Wed May 25 06:14:47 UTC 2022
On 24/05/2022 21:09, Andrei Chichak wrote:
> and the tail end of the log file reads:
> /bin/sh ../../libtool --tag CXX --tag disable-shared --mode=compile
> /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/./gcc/xgcc
> -shared-libgcc
> -B/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/./gcc
> -nostdinc++
> -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/src
> -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/src/.libs -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/libsupc++/.libs -nostdinc -B/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-
> x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/newlib/ -isystem/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/newlib/targ-include
> -isystem
> /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/newlib/libc/include
> -B/Users/andreichichak/quick-start/rtems/6/arm-rtems6/bin/
> -B/Users/andreichichak/quick-start/rtems/6/arm-rtems6/lib/ -isystem /Users/andreichichak/quick-start/rtems/6/arm-rtems6/include -isystem /Users/andreichichak/quick-start/rtems/6/arm-rtems6/sys-include -march=armv5te+fp -mfloat-abi=hard -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/../libgcc -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18
> .7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/arm-rtems6 -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/libsupc++ -std=gnu++98 -fno-implicit-templates -Wall -Wextra -Wwrite-strings -Wcast-qual -Wabi=2 -fdiagnostics-show-location=once -ffunction-sections -fdata-sections -frandom-seed=ios_failure.lo -g -O2 -march=armv5te+fp -mfloat-abi=hard -c -o ios_failure.lo ../../../../../../../gnu-mirror-gcc-197b7ac/libstdc++-v3/src/c++98/ios_failure.cc
> In file included from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/bits/basic_ios.h:37,
> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/ios:44,
> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/istream:38,
> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/fstream:38,
> from ../../../../../../../gnu-mirror-gcc-197b7ac/libstdc++-v3/src/c++98/globals_io.cc:24:
> /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/bits/locale_facets.h:1546:10: fatal error: bits/ctype_inline.h: No such file or directory
> 1546 | #include <bits/ctype_inline.h>
This error is not reported by clang, it is an error produced by the GCC
cross compiler. I guess this is an issue with the build system. Do you
see the ctype_inline.h file in your build tree? Does it work if you run
make in the existing build tree?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
