Building newly for 6/rtems-arm blows on compiling iOS_failure.cc
Mr. Andrei Chichak
groups at chichak.ca
Wed May 25 20:30:23 UTC 2022
Yes, I noticed it was not clang but gcc that was complaining about -------> <—— that long after I hit send. I was hoping for your forgiveness.
I went into /Users/andreichichak/quick-start/src/rsb and did a find . -name ctype_inline.h
I love being able to cut/paste between computers.
Giving:
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bionic/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/qnx/qnx6.1/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/vxworks/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/uclibc/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/djgpp/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/hpux/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/newlib/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bsd/dragonfly/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bsd/netbsd/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bsd/freebsd/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bsd/openbsd/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/bsd/darwin/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/mingw32/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/gnu-linux/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/generic/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/solaris/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/tpf/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/mingw32-w64/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/config/os/aix/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h <—— this one
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/armv7-r+fp/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/cortex-m7/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/armv7-r/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/cortex-r52/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/armv7-a/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/armv6-m/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/armv7-a+simd/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/cortex-m3/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/cortex-m4/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/thumb/cortex-m4+nofp/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/eb/thumb/armv7-r+fp/hard/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/eb/thumb/armv7-r/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
./rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/libstdc++-v3/include/arm-rtems6/bits/ctype_inline.h
From what I can see in the compile line (dark below) should include the file noted above.
(later)
I deleted all of the files that I git cloned and all of the build directories, reran the same scripts as before and it built all of the tools properly. I have no idea why. Unless something got pushed into the repos since yesterday.
So, (?) thank you (?) I think it’s okay now.
Andrei
> On 2022-May-25, at 00:14, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 24/05/2022 21:09, Andrei Chichak wrote:
>> and the tail end of the log file reads:
>> /bin/sh ../../libtool --tag CXX --tag disable-shared --mode=compile /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/./gcc/xgcc -shared-libgcc -B/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/./gcc -nostdinc++ -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/src -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/src/.libs -L/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/libsupc++/.libs -nostdinc -B/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-
>> x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/newlib/ -isystem/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/newlib/targ-include -isystem /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/newlib/libc/include -B/Users/andreichichak/quick-start/rtems/6/arm-rtems6/bin/ -B/Users/andreichichak/quick-start/rtems/6/arm-rtems6/lib/ -isystem /Users/andreichichak/quick-start/rtems/6/arm-rtems6/include -isystem /Users/andreichichak/quick-start/rtems/6/arm-rtems6/sys-include -march=armv5te+fp -mfloat-abi=hard -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/../libgcc -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18
>> .7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/arm-rtems6 -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include -I/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/gnu-mirror-gcc-197b7ac/libstdc++-v3/libsupc++ -std=gnu++98 -fno-implicit-templates -Wall -Wextra -Wwrite-strings -Wcast-qual -Wabi=2 -fdiagnostics-show-location=once -ffunction-sections -fdata-sections -frandom-seed=ios_failure.lo -g -O2 -march=armv5te+fp -mfloat-abi=hard -c -o ios_failure.lo ../../../../../../../gnu-mirror-gcc-197b7ac/libstdc++-v3/src/c++98/ios_failure.cc
>> In file included from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/bits/basic_ios.h:37,
>> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/ios:44,
>> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/istream:38,
>> from /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/fstream:38,
>> from ../../../../../../../gnu-mirror-gcc-197b7ac/libstdc++-v3/src/c++98/globals_io.cc:24:
>> /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-gcc-197b7ac-newlib-64b2081-x86_64-apple-darwin18.7.0-1/build/arm-rtems6/armv5te+fp/hard/libstdc++-v3/include/bits/locale_facets.h:1546:10: fatal error: bits/ctype_inline.h: No such file or directory
>> 1546 | #include <bits/ctype_inline.h>
> This error is not reported by clang, it is an error produced by the GCC cross compiler. I guess this is an issue with the build system. Do you see the ctype_inline.h file in your build tree? Does it work if you run make in the existing build tree?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
