RTEMS 5 on mcp750 fails
Miroslaw Dach miroslaw.dach at gmail.com
Thu Oct 13 01:35:59 UTC 2022
Hi Joel,
I still did not resolve the problem with my CPU card  mcp750 with 32MB. I
would like to run RTEMS5 + EPICS7 on it.
I have tried to tweak various options in
<EPICS_BASE>/modules/libcom/RTEMS/posix/rtems_config.c
but still the same:
The error messages I get are:
pthread_create error No more processes
CAS: unable to start the event facility
The problem refers, I guess, to too small size of memory for mallocs (as i
have shown in my previous email in this thread)
My <EPICS_BASE>/modules/libcom/RTEMS/posix/rtems_config.c looks like:
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE  (128*1024)
#define CONFIGURE_MAXIMUM_PERIODS       5
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
#define CONFIGURE_MALLOC_STATISTICS     1
/* MINIMUM_STACK_SIZE == 8K */
#define CONFIGURE_EXTRA_TASK_STACKS         (2048 *
RTEMS_MINIMUM_STACK_SIZE) /* 16MB */
#if __RTEMS_MAJOR__ > 4
#define CONFIGURE_FILESYSTEM_DEVFS
#define CONFIGURE_FILESYSTEM_TFTPFS
#endif
#define CONFIGURE_FILESYSTEM_NFS
#define CONFIGURE_FILESYSTEM_IMFS
#ifndef RTEMS_LEGACY_STACK
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
/* Configure LibBSD. */
#define RTEMS_BSD_CONFIG_BSP_CONFIG
#define RTEMS_BSD_CONFIG_INIT
#include <machine/rtems-bsd-config.h>
#endif // not LEGACY_STACK
/* Max FDs cannot exceed FD_SETSIZE from newlib (64) */
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 64
#define CONFIGURE_IMFS_ENABLE_MKFIFO    2
#define CONFIGURE_MAXIMUM_NFS_MOUNTS            3
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS       5
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
#define CONFIGURE_UNLIMITED_OBJECTS
*#define CONFIGURE_UNIFIED_WORK_AREAS*
#define CONFIGURE_STACK_CHECKER_ENABLED
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE (128 * 1024)
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 8
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE (2 * 1024 * 1024)
>If it is configured for unified workspace, you wouldn't specify extra
stacks and this wouldn't have been tripped.
>Unified and unlimited can avoid some issues.
Do you think that for the card with 32MB of RAM better option would be to
use just:
#define CONFIGURE_EXECUTIVE_RAM_SIZE (30*1024*1024)
Best Regards
Mirek
pon., 23 maj 2022 o 17:55 Miroslaw Dach <miroslaw.dach at gmail.com>
napisał(a):
> I have changed the CONFIGURE_EXTRA_TASK_STACKS
> from
> #define CONFIGURE_EXTRA_TASK_STACKS         (4000 *
> down to
> #define CONFIGURE_EXTRA_TASK_STACKS         (3000 *
> so now it is 24MB instead of the original 32MB.
> The system boots now without the error: INTERNAL_ERROR_TOO_LITTLE_WORKSPACE
> Unfortunately the problem is not completely solved:
> I get error periodic error message:
> I used the diagnostic shell command:
> rt malloc :
> Number of free blocks:                              28
> Largest free block:                               6288
> Total bytes free:                                12456
> Number of used blocks:                           16522
> Largest used block:                            1048848
> Total bytes used:                             30342640
> Size of the allocatable area in bytes:        30355096
> Minimum free size ever in bytes:                 12456
> Maximum number of free blocks ever:                107
> Maximum number of blocks searched ever:             54
> Lifetime number of bytes allocated:           31278104
> Lifetime number of bytes freed:                 917336
> Total number of searches:                        37008
> Total number of successful allocations:          18126
> Total number of failed allocations:                  40
> Total number of successful frees:                 1604
> Total number of successful resizes:                169
> It looks like there is problem with the memory allocation (Total number of
> failed allocations:                  40)
> It is also quit small Number of free blocks: (Number of free blocks:
>                        28)
> Could you advise me please which config parameters to tweak to resolve the
> issue with the number of failed allocations. I hope that the RAM size
> (32MB) of the mcp750 card is good enough.
> Best Regards
> Mirek
> sob., 21 maj 2022 o 12:42 Miroslaw Dach <miroslaw.dach at gmail.com>
> napisał(a):
>> Hi Joel,
>> Do you mean that CONFIGURE_EXTRA_TASK_STACKS is not taken into account
>> when CONFIGURE_UNIFIED_WORK_AREAS is defined?
>> I have checked
>> the powerpc-rtems5/mcp750/lib/include/rtems/confdefs/wkspace.h and it seems
>> the CONFIGURE_EXTRA_TASK_STACKS is used to calculate the stack size?
>> #define _CONFIGURE_STACK_SPACE_SIZE \
>>   ( _CONFIGURE_INIT_TASK_STACK_EXTRA \
>>     + _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA \
>>     + _CONFIGURE_LIBBLOCK_TASKS_STACK_EXTRA \
>>     + CONFIGURE_EXTRA_TASK_STACKS \
>>     + rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) \
>>       * _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) \
>> CONFIGURE_MAXIMUM_POSIX_THREADS ) \
>> CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) \
>>     + _CONFIGURE_HEAP_HANDLER_OVERHEAD )
>> #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
>> What is the meaning of CONFIGURE_UNLIMITED_ALLOCATION_SIZE . Does it
>> express the size in KB?
>> Currently epics defines:
>> Best Regards
>> Mirek
>> sob., 21 maj 2022 o 10:06 Joel Sherrill <joel at rtems.org> napisał(a):
>>> On Sat, May 21, 2022, 11:02 AM Miroslaw Dach <miroslaw.dach at gmail.com>
>>> wrote:
>>>> Hi Hainz,
>>>> Thanks for the indication. I have exactly found this setting and am
>>>> going to reduce
>>>> CONFIGURE_EXTRA_TASK_STACKS which is currently setup by default in
>>>> EPICS to 32MB.
>>>> The mcp750 has just 32MB so it is no wonder that it does not work.
>>> --joel
>>>> I will test the new configuration next week.
>>>> Have a nice weekend
>>>> Best Regards
>>>> Mirek
>>>> sob., 21 maj 2022 o 05:39 Heinz Junkes <junkes at fhi-berlin.mpg.de>
>>>> napisał(a):
>>>>> Hi Mirek,
>>>>> You can find the configuration of the RTEMS at EPICS here:
>>>>> epics-base/modules/libcom/RTEMS/posix/rtems_config.c
>>>>> There for example
>>>>> best regards,
>>>>> Heinz
>>>>> > On 21. May 2022, at 00:21, Joel Sherrill <joel at rtems.org> wrote:
>>>>> > On Fri, May 20, 2022 at 3:55 PM Miroslaw Dach <
>>>>> > wrote:
>>>>> >> Hi Chris,
>>>>> >> Thank you very much for your expertise and attached links which are
>>>>> very
>>>>> >> helpful.
>>>>> >> As regards the INTERNAL_ERROR_TOO_LITTLE_WORKSPACE error message:
>>>>> >> Is it possible to determine with some debug information what is the
>>>>> >> foreseen by RTEMS WORKSPACE size?
>>>>> > This CONFIGURE_MEMORY_OVERHEAD is there as a mechanism to toss
>>>>> > extra memory at the workspace in case confdefs.h makes a mistake. I
>>>>> think
>>>>> > this
>>>>> > is more likely to be something else like a misconfigured system. But
>>>>> adding
>>>>> > this
>>>>> > to your RTEMS configuration with some chunk of memory like 128K might
>>>>> > allow this to proceed. But if it is a memory allocation error in the
>>>>> BSP
>>>>> > like
>>>>> > not assigning memory right to RTEMS, this won't fix it. See:
>>>>> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-memory-overhead
>>>>> > Chris has touched one of the boards in the motorola_powerpc family
>>>>> > more recently than I have. I would think this would work unless
>>>>> something
>>>>> > is off in the EPICS configuration of RTEMS. There was a discussion
>>>>> of the
>>>>> > EPICS RTEMS configuration with Till recently on tech-talk and I
>>>>> thought
>>>>> > it looked ok.
>>>>> > --joel
>>>>> >> Best Regards
>>>>> >> Mirek
>>>>> >> śr., 18 maj 2022 o 00:53 Chris Johns <chrisj at rtems.org> napisał(a):
>>>>> >>> On 18/5/2022 9:36 am, Miroslaw Dach wrote:
>>>>> >>>> Dear RTEMS Users and Developers,
>>>>> >>>> I have built RTEMS 5 with EPICS 7 and tried to boot my
>>>>> application on
>>>>> >>>> mcp750 cPCI board.
>>>>> >>>> The first thing that I have encountered is that the boot file is
>>>>> in the
>>>>> >>> elf
>>>>> >>>> format so I have
>>>>> >>>> converted it to the binary one.:
>>>>> >>>> powerpc-rtems5-objcopy -I elf32-powerpc -O binary myApp.boot
>>>>> >>> myApp.boot.bin
>>>>> >>> We removed the various post-link hooks.
>>>>> >>>> So far so good
>>>>> >>>> Next, I booted the system with my app and it fails in the
>>>>> *bsp_early*
>>>>> >>>> function in
>>>>> >>>> bsps/powerpc/motorola_powerpc/start/bspstart.c
>>>>> >>>> The boot sequence:
>>>>> >>>> Network Boot File load in progress... To abort hit <BREAK>
>>>>> >>>> Bytes Received =&1270208, Bytes Loaded =&1270208
>>>>> >>>> Bytes/Second =&635104, Elapsed Time =2 Second(s)
>>>>> >>>> Residual-Data Located at: $01F88000
>>>>> >>>> Model: (e2)
>>>>> >>>> Serial: MOT0000000
>>>>> >>>> Processor/Bus frequencies (Hz): 366680480/66671508
>>>>> >>>> Time Base Divisor: 4000
>>>>> >>>> Memory Size: 2000000
>>>>> >>>> Residual: 1f88000 (length 27148)
>>>>> >>>> PCI: Probing PCI hardware
>>>>> >>>> RTEMS 5.0.0/PPC load:
>>>>> >>>> Uncompressing the kernel...
>>>>> >>>> done
>>>>> >>>> Now booting...
>>>>> >>>> Welcome to rtems-5.0.0 (PowerPC/Generic (classic FPU)/mcp750) on
>>>>> >> Mesquite
>>>>> >>>> cPCI (MCP750)
>>>>> >>>> idreg 0 = 0x1208029271
>>>>> >>>> OpenPIC found at 0xc1000000.
>>>>> >>>> pci : Configuring interrupt routing for 'Mesquite cPCI (MCP750)'
>>>>> >>>> pci : No bridge from bus 0 towards root found
>>>>> >>>> pci : Device 1:0x0b:0 routed to interrupt_line 27
>>>>> >>>> pci : Device 1:0x0d:0 routed to interrupt_line 25
>>>>> >>>> Cleared PCI errors: pci_stat was 0x2280
>>>>> >>>> OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0x3238002688
>>>>> >>>> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
>>>>> >>>> OpenPIC timer frequency is 8333848 Hz
>>>>> >>> This all looks OK.
>>>>> >>>> *** FATAL ***
>>>>> >>>> fatal source: 0 (INTERNAL_ERROR_CORE)
>>>>> >>>> fatal code: 2 (INTERNAL_ERROR_TOO_LITTLE_WORKSPACE)
>>>>> >>>> RTEMS version:
>>>>> 5.0.0.fc89cc76804499eba3f3bc4097b795a84f07571a-modified
>>>>> >>>> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6225eadda1de), Newlib
>>>>> >>> 7947581)
>>>>> >>>> executing thread is NULL
>>>>> >>>> My application in the binary format uncompressed with stripped
>>>>> symbols
>>>>> >>> is a
>>>>> >>>> 2.3M + 501K bootloader so I do not think that it
>>>>> >>>> is an issue with the WORKSPACE? The mcp750 has 32MB of RAM.
>>>>> >>>> How to detect what is the real cause of
>>>>> >>>> Would it be the problem with the linker script ppcboot.lds?
>>>>> >>> I do not think so. I suggest you check the Classic API Guide here:
>>>>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/intro.html#sizing-the-rtems-workspace
>>>>> >>> The accounting of memory is better and this means the extra space
>>>>> needed
>>>>> >>> may
>>>>> >>> need to be adjusted. I am not sure where in EPCIS this is
>>>>> controlled and
>>>>> >>> if it
>>>>> >>> can be overridden in your local configuration.
>>>>> >>> RTEMS 5 has a unified workspace and heap. This means the heap and
>>>>> >>> workspace can
>>>>> >>> use memory until it is all used. The benefit is not need to manage
>>>>> the
>>>>> >>> workspace
>>>>> >>> size statically:
>>>>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/general.html#configure-unified-work-areas
>>>>> >>> Chris
>>>>> >> _______________________________________________
>>>>> >> users mailing list
>>>>> >> users at rtems.org
>>>>> >> http://lists.rtems.org/mailman/listinfo/users
>>>>> > users mailing list
>>>>> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20221012/3f394c35/attachment-0001.htm>
