RTEMS5 and file descriptors
Miroslaw Dach miroslaw.dach at gmail.com
Mon Oct 17 17:22:58 UTC 2022
Hello,
I have followed the instruction to change  the limit of File Descriptors
higher than 64:
https://docs.rtems.org/branches/master/user/migration/v4_11-to-v5.html
chapter 13.1.3. File Descriptors
Is it required to rebuild the RTEMS5 kernel with the
macro FD_SETSIZE set to the higher value then 64 or is it enough to
set it  along with CONFIGURE_MAXIMUM_FILE_DESCRIPTORS when the application
is built?
Best Regards
Mirek
URL: <http://lists.rtems.org/pipermail/users/attachments/20221017/fc036cc4/attachment.htm>
