Is rtems interrupt latency good enough for BLDC ESC? (on arm cortex-M or cortex-R)
Y. HB
sprhawk at gmail.com
Mon Sep 5 13:55:23 UTC 2022
Just Curious,
As for the title.
I found an old article:
https://docs.rtems.org/releases/rtemsdocs-4.6.0pre5/share/rtems/html/supplements/m68k/m68k00062.html,
it said rtems's interrupt latency on MC68020 is The maximum period with
interrupts disabled + 9 microseconds on 20Mhz.
I see zephyr provided a "Zero-Latency interrupt" facility to do with near
bare metal performance interrupt handler, and a talk is about using
Zero-Latency Interrupts feature to make a ESC with ZephyRTOS.
Is rtems good enough to do the same thing?
URL: <http://lists.rtems.org/pipermail/users/attachments/20220905/e2cd9fff/attachment.htm>
