What is the preferable way to add new BSP (for stm32 family)
Karel Gardas karel.gardas at centrum.cz
Sun Sep 11 13:57:09 UTC 2022
Not sure about recent progress but IIRC Duc Doan (cced) is also using
STM provided HAL for his work on GPIO driver for F4 BSP. Please see [1]
and [2].
If however you consider HAL to be too heavy weight solution, perhaps you
may have a look into STM provided LL (low-layers drivers) API? This
should be more light weight low level API but with less portability.
Please see UM1786[3].
Important question here is also a question of licensing. Last few
releases of at least H7 HAL were done under Apache 2.0 license. F4 seems
to be the same case and I would bet F3 would be same too. I mention that
as RTEMS developers still need to kind of discuss Apache 2.0 licensed
code in the project. Opinion were still not settled before summer
holidays break but I do not know if there is any movement on this front.
Thanks,
Karel
[1]: https://devel.rtems.org/wiki/GSoC/2022
[2]: https://medium.com/@dtbpkmte
[3]:
https://www.st.com/content/ccc/resource/technical/document/user_manual/a6/79/73/ae/6e/1c/44/14/DM00122016.pdf/files/DM00122016.pdf/jcr:content/translations/en.DM00122016.pdf
On 9/10/22 18:20, Y. HB wrote:
> I have seen in rtems 6.0, there are two stm32 families: stm32f4 and stm32h7
> The former one uses custom code to set up BSP, while the latter one uses
> the ST provided HAL lib to set up BSP.
> Now I need to add a BSP for stm32f3, which is very different (reg
> layout) from stm32f4.
> To add stm32f3 BSP as the stm32f4 approach is tedious and error prone,
> but slim codebase,
> the stm32h7 way has full capabilities provided via ST HAL, but may be
> too bloat if many stm32 families being added into source tree.
> So what is your suggestions? Which is a preferable way ?
> Thanks
> users mailing list
> users at rtems.org
