RSB build fails on M1 Macbook Pro
Karel Gardas karel.gardas at centrum.cz
Tue Sep 20 13:17:17 UTC 2022
Usually just last page is enough. Anyway, your report reports that the
compilation fails on gdb configure with:
configure: WARNING: MPFR is missing or unusable; some features may be
unavailable.
checking whether to use python... /opt/homebrew/bin/python3
checking for python... no
configure: error: no usable python found at /opt/homebrew/bin/python3
make[1]: *** [configure-gdb] Error 1
if you look into gdb build directory you will see config.log there which
may tell you more about why your homebrew python3 fails.
Karel
On 9/20/22 15:02, Andrew Butterfield wrote:
> Hi Karel,
> here it is - I didn't want to attach this unless necessary!
> Regards,
>    Andrew
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                           http://www.scss.tcd.ie/Andrew.Butterfield/
> -----Original Message-----
> From: Karel Gardas <karel.gardas at centrum.cz>
> Date: Tuesday 20 September 2022 at 14:00
> To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "users at rtems.org" <users at rtems.org>
> Subject: Re: RSB build fails on M1 Macbook Pro
>      JFYI: 2 months ago I pushed patches in order to make M1 working at least
>      for arm target. As devil is in the detail you will also need to provide
>      rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
>      investigation.
>      Karel
>      On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
>      > Dear all,
>      > I tried to follow the Quickstart on my new M1 Macbook Pro (Apple Silicon),
>      > which one of my students is also trying to do.
>      > It fails with the following error
>      > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
>      > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      > error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      > Build FAILED
>      >    See error report: rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt
>      > Build Set: Time 0:06:26.055237
>      > Build Set: Time 0:06:26.058387
>      > Build FAILED
>      > python maps to /usr/local/bin/python - it's a Mach-O 64-bit executable x86_64
>      > python --version is 3.6.8
>      > There is a  homebrew python3 but it's an arm64 executable, so seems not to be implicated.
>      > The full terminal transcript is attached
>      > Regards,
>      >    Andrew
>      > _______________________________________________
>      > users mailing list
>      > users at rtems.org
>      > http://lists.rtems.org/mailman/listinfo/users
