RSB build fails on M1 Macbook Pro
Joel Sherrill
joel at rtems.org
Tue Sep 20 13:19:21 UTC 2022
On Tue, Sep 20, 2022 at 8:17 AM Karel Gardas <karel.gardas at centrum.cz>
wrote:
> Usually just last page is enough. Anyway, your report reports that the
> compilation fails on gdb configure with:
> configure: WARNING: MPFR is missing or unusable; some features may be
> unavailable.
> checking whether to use python... /opt/homebrew/bin/python3
> checking for python... no
> configure: error: no usable python found at /opt/homebrew/bin/python3
> make[1]: *** [configure-gdb] Error 1
> if you look into gdb build directory you will see config.log there which
> may tell you more about why your homebrew python3 fails.
That's usually a misleading message. You have Python but not the
associated python-devel or whatever it is called in that environment.
It can't find the Python.h file I think is what it will be if you look in
the
right config.log.
--joel
> Karel
> On 9/20/22 15:02, Andrew Butterfield wrote:
> > Hi Karel,
> > here it is - I didn't want to attach this unless necessary!
> > Regards,
> > Andrew
> > Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> > Lero at TCD, Head of Software Foundations & Verification Research Group
> > School of Computer Science and Statistics,
> > Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> > http://www.scss.tcd.ie/Andrew.Butterfield/
> > -----Original Message-----
> > From: Karel Gardas <karel.gardas at centrum.cz>
> > Date: Tuesday 20 September 2022 at 14:00
> > To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "
> users at rtems.org" <users at rtems.org>
> > Subject: Re: RSB build fails on M1 Macbook Pro
> > JFYI: 2 months ago I pushed patches in order to make M1 working at
> least
> > for arm target. As devil is in the detail you will also need to
> provide
> > rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
> > investigation.
> > Karel
> > On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
> > > Dear all,
> > > I tried to follow the Quickstart on my new M1 Macbook Pro (Apple
> Silicon),
> > > which one of my students is also trying to do.
> > > It fails with the following error
> > > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
> > > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> > > error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> > > Build FAILED
> > > See error report:
> > > Build Set: Time 0:06:26.055237
> > > Build Set: Time 0:06:26.058387
> > > Build FAILED
> > > python maps to /usr/local/bin/python - it's a Mach-O 64-bit
> executable x86_64
> > > python --version is 3.6.8
> > > There is a homebrew python3 but it's an arm64 executable, so
> seems not to be implicated.
> > > The full terminal transcript is attached
> > > Regards,
> > > Andrew
> +353-1-677-2204
> Group
> Dublin
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20220920/76e8e3e7/attachment.htm>
