RSB build fails on M1 Macbook Pro
Andrew.Butterfield at scss.tcd.ie
Tue Sep 20 13:35:56 UTC 2022
Hi Karel,
Gdb config.log now attached
Andrew
On 20/09/2022, 14:17, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
Usually just last page is enough. Anyway, your report reports that the
compilation fails on gdb configure with:
configure: WARNING: MPFR is missing or unusable; some features may be
unavailable.
checking whether to use python... /opt/homebrew/bin/python3
checking for python... no
configure: error: no usable python found at /opt/homebrew/bin/python3
make[1]: *** [configure-gdb] Error 1
if you look into gdb build directory you will see config.log there which
may tell you more about why your homebrew python3 fails.
Karel
On 9/20/22 15:02, Andrew Butterfield wrote:
> Hi Karel,
> here it is - I didn't want to attach this unless necessary!
> Regards,
> Andrew
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
> -----Original Message-----
> From: Karel Gardas <karel.gardas at centrum.cz>
> Date: Tuesday 20 September 2022 at 14:00
> To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "users at rtems.org" <users at rtems.org>
> Subject: Re: RSB build fails on M1 Macbook Pro
> JFYI: 2 months ago I pushed patches in order to make M1 working at least
> for arm target. As devil is in the detail you will also need to provide
> rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
> investigation.
> Karel
> On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
> > Dear all,
> > I tried to follow the Quickstart on my new M1 Macbook Pro (Apple Silicon),
> > which one of my students is also trying to do.
> > It fails with the following error
> > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
> > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> > error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> > Build FAILED
> > See error report: rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt
> > Build Set: Time 0:06:26.055237
> > Build Set: Time 0:06:26.058387
> > Build FAILED
> > python maps to /usr/local/bin/python - it's a Mach-O 64-bit executable x86_64
> > python --version is 3.6.8
> > There is a homebrew python3 but it's an arm64 executable, so seems not to be implicated.
> > The full terminal transcript is attached
> > Regards,
> > Andrew
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
Desc: config.log
URL: <http://lists.rtems.org/pipermail/users/attachments/20220920/9a2a70b7/attachment-0001.obj>
