RSB build fails on M1 Macbook Pro
Karel Gardas karel.gardas at centrum.cz
Tue Sep 20 15:35:18 UTC 2022
Well, obviously, I would fix that by installing the library. But anyway,
gdb is IIRC compiled before GCC which probably also means you will be
missing mpfr and mpc too -- so best way for you may be following
https://gcc.gnu.org/install/prerequisites.html
IIRC libraries are nice enough to provide pkg config scripts, but really
just IIRC, you need to investigate yourself how to make them "available"
for RSB.
BTW, the required libraries are also mentioned here:
https://docs.rtems.org/branches/master/user/rsb/why-build-from-source.html
Cheers,
Karel
On 9/20/22 15:56, Andrew.Butterfield at scss.tcd.ie wrote:
> How do I fix this?
> On 20/09/2022, 14:41, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
>      You are missing isl library header file:
>      configure:6284: /usr/bin/cc -O2 -pipe -fbracket-depth=1024
>      -I/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/include
>      -o conftest -g -O2
>      -L/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/lib
>        -lisl -lmpc -lmpfr -lgmp conftest.c  -lisl -lgmp >&5
>      conftest.c:10:10: fatal error: 'isl/schedule.h' file not found
>      #include <isl/schedule.h>
>      1 error generated.
>      Karel
>      On 9/20/22 15:35, Andrew.Butterfield at scss.tcd.ie wrote:
>      > Hi Karel,
>      > Gdb config.log now attached
>      > Andrew
>      > On 20/09/2022, 14:17, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
>      >      Usually just last page is enough. Anyway, your report reports that the
>      >      compilation fails on gdb configure with:
>      >      configure: WARNING: MPFR is missing or unusable; some features may be
>      >      unavailable.
>      >      checking whether to use python... /opt/homebrew/bin/python3
>      >      checking for python... no
>      >      configure: error: no usable python found at /opt/homebrew/bin/python3
>      >      make[1]: *** [configure-gdb] Error 1
>      >      if you look into gdb build directory you will see config.log there which
>      >      may tell you more about why your homebrew python3 fails.
>      >      Karel
>      >      On 9/20/22 15:02, Andrew Butterfield wrote:
>      >      > Hi Karel,
>      >      > here it is - I didn't want to attach this unless necessary!
>      >      > Regards,
>      >      >    Andrew
>      >      > Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
>      >      > Lero at TCD, Head of Software Foundations & Verification Research Group
>      >      > School of Computer Science and Statistics,
>      >      > Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>      >      >                           http://www.scss.tcd.ie/Andrew.Butterfield/
>      >      > -----Original Message-----
>      >      > From: Karel Gardas <karel.gardas at centrum.cz>
>      >      > Date: Tuesday 20 September 2022 at 14:00
>      >      > To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "users at rtems.org" <users at rtems.org>
>      >      > Subject: Re: RSB build fails on M1 Macbook Pro
>      >      >      JFYI: 2 months ago I pushed patches in order to make M1 working at least
>      >      >      for arm target. As devil is in the detail you will also need to provide
>      >      >      rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
>      >      >      investigation.
>      >      >      Karel
>      >      >      On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
>      >      >      > Dear all,
>      >      >      > I tried to follow the Quickstart on my new M1 Macbook Pro (Apple Silicon),
>      >      >      > which one of my students is also trying to do.
>      >      >      > It fails with the following error
>      >      >      > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
>      >      >      > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      >      >      > error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      >      >      > Build FAILED
>      >      >      >    See error report: rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt
>      >      >      > Build Set: Time 0:06:26.055237
>      >      >      > Build Set: Time 0:06:26.058387
>      >      >      > Build FAILED
>      >      >      > python maps to /usr/local/bin/python - it's a Mach-O 64-bit executable x86_64
>      >      >      > python --version is 3.6.8
>      >      >      > There is a  homebrew python3 but it's an arm64 executable, so seems not to be implicated.
>      >      >      > The full terminal transcript is attached
>      >      >      > Regards,
>      >      >      >    Andrew
>      >      >      > _______________________________________________
>      >      >      > users mailing list
>      >      >      > users at rtems.org
>      >      >      > http://lists.rtems.org/mailman/listinfo/users
