RSB build fails on M1 Macbook Pro
Wed Sep 21 03:49:21 UTC 2022
On 21/9/2022 1:35 am, Karel Gardas wrote:
> Well, obviously, I would fix that by installing the library. But anyway, gdb is
> IIRC compiled before GCC which probably also means you will be missing mpfr and
> mpc too -- so best way for you may be following
> https://gcc.gnu.org/install/prerequisites.html
> IIRC libraries are nice enough to provide pkg config scripts, but really just
> IIRC, you need to investigate yourself how to make them "available" for RSB.
> BTW, the required libraries are also mentioned here:
> https://docs.rtems.org/branches/master/user/rsb/why-build-from-source.html
Yeap.
> Cheers,
> Karel
> On 9/20/22 15:56, Andrew.Butterfield at scss.tcd.ie wrote:
>> How do I fix this?
Andrew,
I have required for decades the RSB builds tools for MacOS with just Xcode.
Recent updates by Apple to MacOS has effected using the MacOS provided python
with a gdb build in some rather unpleasant ways. I will spare you the detail but
 Xocde is now set up so you cannot link the python runtime. I have not had time
to find a workable solution. I can see 2 possible paths long term ...
1. Disable python in GDB. I do not like this as pretty printers are used with C++
2. Detect and use a python.org installed Python
Watching the changes it seems Apple has been removing a bunch of things from the
OS it use to provide. For example Emacs as gone I think that is a good decision
because you can download a better more current version than Apple provided.
Maybe the same is happening with Python given python.org has a current and easy
to install solution.
In the very early days of the RSB when it was called SpecBuilder I stepped into
Homebrew or Macports, not sure which, and got lost deep in the weeds of detail.
I kept having issues with installed libraries when building gcc. I started
becoming more focused on dependent packages and fixes in them than a gcc build
for RTEMS. This was decades ago and I am not sure what the current state of
Homebrew or Macports are. If the RSB can work with them that would be great and
I would happily accept patches but it is not something I will spend time on.
>> On 20/09/2022, 14:41, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
>>      You are missing isl library header file:
>>      configure:6284: /usr/bin/cc -O2 -pipe -fbracket-depth=1024
>> -I/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/include
>>      -o conftest -g -O2
>> -L/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/lib
>>        -lisl -lmpc -lmpfr -lgmp conftest.c  -lisl -lgmp >&5
>>      conftest.c:10:10: fatal error: 'isl/schedule.h' file not found
>>      #include <isl/schedule.h>
>>      1 error generated.
>>      Karel
>>      On 9/20/22 15:35, Andrew.Butterfield at scss.tcd.ie wrote:
>>      > Hi Karel,
>>      > Gdb config.log now attached
>>      > Andrew
>>      > On 20/09/2022, 14:17, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
>>      >      Usually just last page is enough. Anyway, your report reports that
>> the
>>      >      compilation fails on gdb configure with:
>>      >      configure: WARNING: MPFR is missing or unusable; some features may be
>>      >      unavailable.
>>      >      checking whether to use python... /opt/homebrew/bin/python3
>>      >      checking for python... no
>>      >      configure: error: no usable python found at /opt/homebrew/bin/python3
>>      >      make[1]: *** [configure-gdb] Error 1
>>      >      if you look into gdb build directory you will see config.log there
>> which
>>      >      may tell you more about why your homebrew python3 fails.
>>      >      Karel
>>      >      On 9/20/22 15:02, Andrew Butterfield wrote:
>>      >      > Hi Karel,
>>      >      > here it is - I didn't want to attach this unless necessary!
>>      >      > Regards,
>>      >      >    Andrew
>>      >      > Andrew Butterfield     Tel: +353-1-896-2517     Fax:
>> +353-1-677-2204
>>      >      > Lero at TCD, Head of Software Foundations & Verification Research
>> Group
>>      >      > School of Computer Science and Statistics,
>>      >      > Room G.39, O'Reilly Institute, Trinity College, University of
>> Dublin
>> http://www.scss.tcd.ie/Andrew.Butterfield/
>>      >      > -----Original Message-----
>>      >      > From: Karel Gardas <karel.gardas at centrum.cz>
>>      >      > Date: Tuesday 20 September 2022 at 14:00
>>      >      > To: "Andrew.Butterfield at scss.tcd.ie"
>> <Andrew.Butterfield at scss.tcd.ie>, "users at rtems.org" <users at rtems.org>
>>      >      > Subject: Re: RSB build fails on M1 Macbook Pro
>>      >      >      JFYI: 2 months ago I pushed patches in order to make M1
>> working at least
>>      >      >      for arm target. As devil is in the detail you will also
>> need to provide
>> rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
>>      >      >      investigation.
>>      >      >      Karel
>>      >      >      On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
>>      >      >      > Dear all,
>>      >      >      > I tried to follow the Quickstart on my new M1 Macbook Pro
>> (Apple Silicon),
>>      >      >      > which one of my students is also trying to do.
>>      >      >      > It fails with the following error
>>      >      >      > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB
>> (100%)
>>      >      >      > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>>      >      >      > error: building
>>      >      >      > Build FAILED
>>      >      >      >    See error report:
>>      >      >      > Build Set: Time 0:06:26.055237
>>      >      >      > Build Set: Time 0:06:26.058387
>>      >      >      > Build FAILED
>>      >      >      > python maps to /usr/local/bin/python - it's a Mach-O
>> 64-bit executable x86_64
>>      >      >      > python --version is 3.6.8
>>      >      >      > There is a  homebrew python3 but it's an arm64
>> executable, so seems not to be implicated.
>>      >      >      > The full terminal transcript is attached
>>      >      >      > Regards,
>>      >      >      >    Andrew
>>      >      >      > Andrew Butterfield     Tel: +353-1-896-2517     Fax:
>> +353-1-677-2204
>>      >      >      > Lero at TCD, Head of Software Foundations & Verification
>> Research Group
>>      >      >      > School of Computer Science and Statistics,
>>      >      >      > Room G.39, O'Reilly Institute, Trinity College,
>> University of Dublin
>>      >      >      > _______________________________________________
>>      >      >      > users mailing list
>>      >      >      > users at rtems.org
>>      >      >      > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
