Networking examples
Brett Sterling
brett.sterling at odysseysr.com
Tue Aug 15 16:57:14 UTC 2023
Hello all!
To get this out of the way prior to all of the requested debugging information - I don't need the legacy stack, any networking stack will do. I started with legacy because that was what was shown on the RTEMS documentation pages. We're trying to integrate RTEMS into our system and I considered adding the networking stack that had some documentation a big enough effort without perhaps trying to integrate another network stack. But I'm absolutely glad to go with any suggestion.
Now, onto the requested build failure information.
Following https://docs.rtems.org/branches/master/legacy-networking/quick_start.html
../source-builder/sb-set-builder --prefix=$HOME/src/rtems-net-build 6/rtems-net-legacy --host=sparc-rtems6 --with-rtems-bsp=sparc
RTEMS Source Builder - Set Builder, 6 (8e568b2ca348 modified)
warning: exe: absolute exe found in path: (__cmake) /usr/bin/cmake
Build Set: 6/rtems-net-legacy
config: tools/rtems-net-legacy-6.cfg
error: config error: rtems-bsp.cfg:104: RTEMS tools not found (sparc-rtems6-gcc) found; Please check the --with-tools option or --prefix.
Build FAILED
Build Set: Time 0:00:00.012407
Build FAILED
The error information implies that '--prefix' should specify where the 'sparc-rtems6-gcc' should be located, so I tried something different (specifying where the build tools are located).
prefix=$HOME/src/Toolchains/osr_rtems_6_sparc 6/rtems-net-legacy --host=sparc-rtems6 --with-rtems-bsp=sparc
error: config error: rtems-bsp.cfg:131: RTEMS BSP not found (sparc-rtems6-sparc.pc); Please check the --with-rtems option or --prefix.
Build FAILED
Build Set: Time 0:00:00.014283
Build FAILED
What I'm guessing is that the networking build still relies on everything being in the correct location, but the documentation doesn't indicate where the networking repository should be put and how the networking build fits in with the tools build and the application builds. This is probably the information I'm currently lacking. Then again, I may be missing something in the documentation that I erroneously overlooked. If so, just let me know.
The "Hello World" failure is documented in this ticket: https://devel.rtems.org/ticket/4927
Thanks again in advance!
Brett
________________________________
Sent: Tuesday, August 15, 2023 9:57 AM
To: Brett Sterling <brett.sterling at odysseysr.com>
Cc: users at rtems.org <users at rtems.org>; Vijay Kumar Banerjee <vijay at rtems.org>
Subject: Re: Networking examples
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
I add Vijay since he has been working with this.
On Tue, Aug 15, 2023 at 9:27 AM Brett Sterling <brett.sterling at odysseysr.com<mailto:brett.sterling at odysseysr.com>> wrote:
Hello all,
My goal is to integrate networking into our RTEMS solution, so I started here: https://docs.rtems.org/branches/master/legacy-networking/index.html<https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Flegacy-networking%2Findex.html&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637201789%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=O7Cl3JjG1IGmeX5TzhEdb65bNPtvrK%2BF4Zzqtlw5Zhk%3D&reserved=0>.
But, as soon as I had started, I hit a failure. I tried the 'quick start' (https://docs.rtems.org/branches/master/legacy-networking/quick_start.html<https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Flegacy-networking%2Fquick_start.html&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637358041%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=gCplMFshN695pxIZnLZlIxdIjfO9mkjZXsOzmm8R45s%3D&reserved=0>), but regardless of which way I tried to build, the build failed.
Please post about that. This shouldn't happen.
And Vijay has recent experience testing the legacy stack.
Based on the failure of the 'quick-start' for the RTEMS "Hello World" example coupled with this failure, I'm starting to consider moving back to an older RTEMS version (I've seen networking information for both RTEMS 4 & 5), but first wanted to reach out to the user community to get input.
Let's see how this failed.
Optimally, I would like to find an RTEMS example (any version) WITH NETWORKING that runs on either an RTEMS simulator, or on a commercially available development board so that I can see networking working and then evolve it into my system.
Do you really want the legacy stack or just a network stack?
Less optimally, I would like to find an RTEMS example (any version) WITH NETWORKING that at least completely builds.
If no one has examples of these, I would be glad to try different things to get the networking stuff building. Especially if someone else can show that they can build with networking.
Thanks in advance!
Brett
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users<https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Flists.rtems.org%2Fmailman%2Flistinfo%2Fusers&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637358041%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=emkBfMPRDD5Ncf8xS7x%2BOB3hQwBUEpkMKEh9lK38Mx4%3D&reserved=0>
URL: <http://lists.rtems.org/pipermail/users/attachments/20230815/62de93d3/attachment-0001.htm>
