Networking examples
Joel Sherrill
joel at rtems.org
Tue Aug 15 15:57:28 UTC 2023
I add Vijay since he has been working with this.
On Tue, Aug 15, 2023 at 9:27 AM Brett Sterling <brett.sterling at odysseysr.com>
wrote:
> Hello all,
> My goal is to integrate networking into our RTEMS solution, so I started
> here: https://docs.rtems.org/branches/master/legacy-networking/index.html.
> But, as soon as I had started, I hit a failure. I tried the 'quick start'
> (https://docs.rtems.org/branches/master/legacy-networking/quick_start.html),
> but regardless of which way I tried to build, the build failed.
Please post about that. This shouldn't happen.
And Vijay has recent experience testing the legacy stack.
> Based on the failure of the 'quick-start' for the RTEMS "Hello World"
> example coupled with this failure, I'm starting to consider moving back to
> an older RTEMS version (I've seen networking information for both RTEMS 4 &
> 5), but first wanted to reach out to the user community to get input.
Let's see how this failed.
> Optimally, I would like to find an RTEMS example (any version) *WITH
> NETWORKING* that runs on either an RTEMS simulator, or on a commercially
> available development board so that I can see networking working and then
> evolve it into my system.
Do you really want the legacy stack or just a network stack?
> Less optimally, I would like to find an RTEMS example (any version) *WITH
> NETWORKING* that at least completely builds.
> If no one has examples of these, I would be glad to try different things
> to get the networking stuff building. Especially if someone else can show
> that they can build with networking.
> Thanks in advance!
> Brett
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20230815/309e2f6c/attachment.htm>
