Determining resource usage for BSP drivers
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri Feb 10 13:53:39 UTC 2023
> -----Original Message-----
> From: users <users-bounces at rtems.org> On Behalf Of Sebastian Huber
> Sent: Freitag, 10. Februar 2023 14:23
> To: martinerikwerner.aac at gmail.com; users at rtems.org
> Subject: Re: Determining resource usage for BSP drivers
> On 10.02.23 14:19, martinerikwerner.aac at gmail.com wrote:
> > Some BSP drivers use rtems objects in their implementation, for
> > example GRCAN creating semaphores in bsps/shared/grlib/can/grcan.c.
> > Or is it assumed that the system will be configured with unlimited
> > resources instead in most cases where this could become an issue?
> Yes, it is quite difficult to do the resource accounting for the Classic API
> objects. We rewrote a lot of drivers to use the self-contained
> synchronization objects:
> https://docs.rtems.org/branches/master/c-user/self_contained_objects.html
Ah, very interesting and well explained.
Can one use it as a general rule of thumb for new applications to prefer those self-contained objects instead of the classic rtems_semaphore_create() objects?
And are there any pitfalls when mixing those two APIs or is it safe to do so?
Best regards,
    Jan
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> users mailing list
> users at rtems.org
