Determining resource usage for BSP drivers
Sebastian Huber
Fri Feb 10 14:16:35 UTC 2023
On 10.02.23 14:53, Jan.Sommer at dlr.de wrote:
>> -----Original Message-----
>> From: users<users-bounces at rtems.org> On Behalf Of Sebastian Huber
>> Sent: Freitag, 10. Februar 2023 14:23
>> To:martinerikwerner.aac at gmail.com;users at rtems.org
>> Subject: Re: Determining resource usage for BSP drivers
>> On 10.02.23 14:19,martinerikwerner.aac at gmail.com wrote:
>>> Some BSP drivers use rtems objects in their implementation, for
>>> example GRCAN creating semaphores in bsps/shared/grlib/can/grcan.c.
>>> Or is it assumed that the system will be configured with unlimited
>>> resources instead in most cases where this could become an issue?
>> Yes, it is quite difficult to do the resource accounting for the Classic API
>> objects. We rewrote a lot of drivers to use the self-contained
>> synchronization objects:
>> https://docs.rtems.org/branches/master/c-user/self_contained_objects.html
> Ah, very interesting and well explained.
> Can one use it as a general rule of thumb for new applications to prefer those self-contained objects instead of the classic rtems_semaphore_create() objects?
> And are there any pitfalls when mixing those two APIs or is it safe to do so?
You can mix the APIs as you like. For applications, I would use a
standard API such as POSIX or the C++ library. The POSIX objects perform
a bit more error checking. The self-contained objects mentioned above
are performance optimized.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
