Error in building rtems 5.3 tools via mingw
Giovanni Righi righiqwe at gmail.com
Fri Mar 17 15:22:26 UTC 2023
Good afternoon,
I'm trying to build the rtems 5.3 tools in windows using mingw, but I'm
getting an error during the gdb build.
I'm attaching the logs so you can see what's going on.
URL: <http://lists.rtems.org/pipermail/users/attachments/20230317/614eb57c/attachment-0001.htm>
RTEMS Tools Project - Source Builder Error Report
 Build: error: building arg9xwm1
 Command Line: ../source-builder/sb-set-builder --prefix=C:/opt/rtems/5.3 5/rtems-arm
 Python: 2.7.18 (default, Jan 14 2023, 22:21:24)  [GCC 12.2.0 64 bit (AMD64)]
 RSB: not a valid repo
 Windows
Tail of the build log:
ranlib libsim.a
x86_64-w64-mingw32-gcc -O2 -g -pipe -I/c/opt/rtems/rtems-source-builder-5.3/rtems/build/tmp/sb-197611/5a/c/opt/rtems/5.3/include -DHAVE_CONFIG_H  -DWITH_DEFAULT_ALIGNMENT=STRICT_ALIGNMENT     -DDEFAULT_INLINE=0   -Wall -Wdeclaration-after-statement -Wpointer-arith -Wpointer-sign -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wmissing-prototypes -Wdeclaration-after-statement -Wempty-body -Wmissing-parameter-type -Wold-style-declaration -Wold-style-definition -Wno-format   -DMODET   -I. -I../../../gdb-9.1/sim/arm -I../common -I../../../gdb-9.1/sim/arm/../common -I../../include -I../../../gdb-9.1/sim/arm/../../include -I../../bfd -I../../../gdb-9.1/sim/arm/../../bfd -I../../opcodes -I../../../gdb-9.1/sim/arm/../../opcodes  -g -O2 -D__USE_MINGW_ACCESS -L/c/opt/rtems/rtems-source-builder-5.3/rtems/build/tmp/sb-197611/5a/c/opt/rtems/5.3/lib -Wl,--stack,12582912 -o run.exe \
  nrun.o libsim.a ../../bfd/libbfd.a ../../opcodes/libopcodes.a  ../../libiberty/libiberty.a -L../../zlib -lz -lm
make[3]: Leaving directory '/c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/build/sim/arm'
make[2]: Leaving directory '/c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/build/sim'
make[2]: Entering directory '/c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/build/gdb'
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs arch/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs cli/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs mi/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs gdbsupport/.deps
mkdir -p -- arch/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs compile/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs tui/.deps
mkdir -p -- cli/.deps
mkdir -p -- mi/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs unittests/.deps
mkdir -p -- gdbsupport/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs guile/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs python/.deps
mkdir -p -- compile/.deps
mkdir -p -- tui/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs target/.deps
/bin/sh ../../gdb-9.1/gdb/../mkinstalldirs nat/.deps
mkdir -p -- unittests/.deps
mkdir -p -- guile/.deps
mkdir -p -- python/.deps
mkdir -p -- target/.deps
mkdir -p -- nat/.deps
  GEN    stamp-version
  CXX    xml-support.o
  GEN    xml-builtin.c
  CXX    xml-syscall.o
  CXX    xml-tdesc.o
  CXX    gdb.o
  CXX    aarch32-tdep.o
  CXX    ada-exp.o
  CXX    ada-lang.o
  CXX    ada-tasks.o
  CXX    ada-typeprint.o
  CXX    ada-valprint.o
In file included from ../../gdb-9.1/gdb/ada-lang.c:32:
../../gdb-9.1/gdb/inferior.h: In member function 'void infcall_suspend_state_deleter::operator()(infcall_suspend_state*) const':
../../gdb-9.1/gdb/inferior.h:80:38: warning: 'bool std::uncaught_exception()' is deprecated: use 'std::uncaught_exceptions()' instead [-Wdeprecated-declarations]
   80 |         if (!std::uncaught_exception ())
In file included from C:/msys64/mingw64/include/c++/12.2.0/ext/concurrence.h:34,
                 from C:/msys64/mingw64/include/c++/12.2.0/bits/shared_ptr_base.h:62,
                 from C:/msys64/mingw64/include/c++/12.2.0/bits/shared_ptr.h:53,
                 from C:/msys64/mingw64/include/c++/12.2.0/memory:77,
                 from ../../gdb-9.1/gdb/gdbsupport/common-exceptions.h:25,
                 from ../../gdb-9.1/gdb/gdbsupport/common-defs.h:137,
                 from ../../gdb-9.1/gdb/defs.h:28,
                 from ../../gdb-9.1/gdb/ada-lang.c:21:
C:/msys64/mingw64/include/c++/12.2.0/exception:124:8: note: declared here
  124 |   bool uncaught_exception() _GLIBCXX_USE_NOEXCEPT __attribute__ ((__pure__));
  CXX    ada-varobj.o
  CXX    addrmap.o
In file included from ../../gdb-9.1/gdb/ada-tasks.c:24:
                 from ../../gdb-9.1/gdb/ada-tasks.c:18:
  CXX    agent.o
  CXX    alloc.o
  CXX    annotate.o
  CXX    arch-utils.o
  CXX    arch/aarch32.o
  CXX    arch/arm-get-next-pcs.o
  CXX    arch/arm.o
In file included from ../../gdb-9.1/gdb/annotate.c:26:
                 from ../../gdb-9.1/gdb/annotate.c:19:
In file included from ../../gdb-9.1/gdb/arch-utils.c:24:
                 from ../../gdb-9.1/gdb/arch-utils.c:20:
  CXX    arm-pikeos-tdep.o
  CXX    arm-tdep.o
  CXX    auto-load.o
  CXX    auxv.o
  CXX    ax-gdb.o
  CXX    ax-general.o
  CXX    bcache.o
In file included from ../../gdb-9.1/gdb/arm-tdep.c:25:
                 from ../../gdb-9.1/gdb/arm-tdep.c:20:
  CXX    bfd-target.o
In file included from ../../gdb-9.1/gdb/auxv.c:24:
                 from ../../gdb-9.1/gdb/auxv.c:20:
  CXX    block.o
  CXX    blockframe.o
  CXX    break-catch-sig.o
  CXX    break-catch-syscall.o
  CXX    break-catch-throw.o
  CXX    breakpoint.o
In file included from ../../gdb-9.1/gdb/blockframe.c:29:
                 from ../../gdb-9.1/gdb/blockframe.c:21:
In file included from ../../gdb-9.1/gdb/break-catch-sig.c:25:
                 from ../../gdb-9.1/gdb/break-catch-sig.c:20:
In file included from ../../gdb-9.1/gdb/break-catch-syscall.c:24:
                 from ../../gdb-9.1/gdb/break-catch-syscall.c:20:
In file included from ../../gdb-9.1/gdb/break-catch-throw.c:25:
                 from ../../gdb-9.1/gdb/break-catch-throw.c:20:
  CXX    btrace.o
  CXX    build-id.o
In file included from ../../gdb-9.1/gdb/breakpoint.c:34:
                 from ../../gdb-9.1/gdb/breakpoint.c:20:
  CXX    buildsym-legacy.o
  CXX    buildsym.o
  CXX    c-exp.o
  CXX    c-lang.o
In file included from ../../gdb-9.1/gdb/btrace.c:25:
                 from ../../gdb-9.1/gdb/btrace.c:22:
  CXX    c-typeprint.o
  CXX    c-valprint.o
  CXX    c-varobj.o
  CXX    charset.o
  CXX    cli-out.o
  CXX    cli/cli-cmds.o
  CXX    cli/cli-decode.o
  CXX    cli/cli-dump.o
  CXX    cli/cli-interp.o
  CXX    cli/cli-logging.o
  CXX    cli/cli-option.o
In file included from ../../gdb-9.1/gdb/cli/cli-interp.c:31:
                 from ../../gdb-9.1/gdb/cli/cli-interp.c:20:
  CXX    cli/cli-script.o
  CXX    cli/cli-setshow.o
  CXX    cli/cli-style.o
  CXX    cli/cli-utils.o
  CXX    coff-pe-read.o
  CXX    coffread.o
  CXX    compile/compile-c-support.o
  CXX    compile/compile-c-symbols.o
  CXX    compile/compile-c-types.o
  CXX    compile/compile-cplus-symbols.o
  CXX    compile/compile-cplus-types.o
  CXX    compile/compile-loc2c.o
  CXX    compile/compile-object-load.o
  CXX    compile/compile-object-run.o
In file included from ../../gdb-9.1/gdb/compile/compile-object-load.c:30:
                 from ../../gdb-9.1/gdb/compile/compile-object-load.c:20:
  CXX    compile/compile.o
  CXX    complaints.o
  CXX    completer.o
  CXX    continuations.o
  CXX    copying.o
  CXX    corefile.o
  CXX    corelow.o
In file included from ../../gdb-9.1/gdb/gdbsupport/common-defs.h:132,
                 from ../../gdb-9.1/gdb/compile/compile.c:20:
../../gdb-9.1/gdb/gdbsupport/gdb_unlinker.h: In constructor 'gdb::unlinker::unlinker(const char*)':
../../gdb-9.1/gdb/gdbsupport/gdb_assert.h:35:4: warning: 'nonnull' argument 'filename' compared to NULL [-Wnonnull-compare]
   35 |   ((void) ((expr) ? 0 :                                                       \
   36 |            (gdb_assert_fail (#expr, __FILE__, __LINE__, FUNCTION_NAME), 0)))
../../gdb-9.1/gdb/gdbsupport/gdb_unlinker.h:38:5: note: in expansion of macro 'gdb_assert'
   38 |     gdb_assert (filename != NULL);
../../gdb-9.1/gdb/completer.c: In function 'char* gdb_completion_word_break_characters_throw()':
../../gdb-9.1/gdb/completer.c:1933:10: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
 1933 |   return rl_completer_word_break_characters;
      |          const char*
In file included from ../../gdb-9.1/gdb/continuations.c:22:
                 from ../../gdb-9.1/gdb/continuations.c:20:
  CXX    cp-abi.o
make[2]: *** [Makefile:1656: completer.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from ../../gdb-9.1/gdb/corefile.c:23:
                 from ../../gdb-9.1/gdb/corefile.c:20:
In file included from ../../gdb-9.1/gdb/corelow.c:25:
                 from ../../gdb-9.1/gdb/corelow.c:20:
make[2]: Leaving directory '/c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/build/gdb'
make[1]: *** [Makefile:9237: all-gdb] Error 2
make[1]: Leaving directory '/c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/build'
make: *** [Makefile:859: all] Error 2
shell cmd failed: sh -ex  /c/opt/rtems/rtems-source-builder-5.3/rtems/build/arg9xwm1/do-build
