Error in building rtems 5.3 tools via mingw
Giovanni Righi
righiqwe at gmail.com
Wed Mar 22 14:16:54 UTC 2023
I opened the ticket as requested.
Now I'm having another issue, I re-runned the source-builder but now it
stop with the following error:
+ ./waf
Waf: Entering directory
`C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build'
[ 1/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_convert.m4
Traceback (most recent call last):
File "<string>", line 55, in <module>
File "<string>", line 20, in run
OSError: [Errno 22] Invalid argument
[ 2/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4
Waf: Leaving directory
Build failed
File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
line 181, in exec_command
ret,out,err=Utils.run_process(cmd,kw,cargs)
File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Utils.py",
line 598, in run_process
return run_prefork_process(cmd,kwargs,cargs)
File
line 533, in run_prefork_process
proc.stdin.write(obj)
BrokenPipeError: [Errno 32] Broken pipe
During handling of the above exception, another exception occurred:
File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py",
line 180, in process
ret=self.run()
File "<string>", line 14, in f
File
line 173, in exec_command
return self.generator.bld.exec_command(cmd,**kw)
File
line 183, in exec_command
raise Errors.WafError('Execution failure: %s'%str(e),ex=e)
waflib.Errors.WafError: Execution failure: [Errno 32] Broken pipe
shell cmd failed: sh -ex
/c/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/do-build
error: building rt51
URL: <http://lists.rtems.org/pipermail/users/attachments/20230322/07adddda/attachment.htm>
