Error in building rtems 5.3 tools via mingw
Chris Johns
chrisj at rtems.org
Tue Mar 21 21:50:41 UTC 2023
On 22/3/2023 3:19 am, Giovanni Righi wrote:
> Ok I managed to resolve the problem by updating the gdb to gdb-12 as you suggested.
> Just for information if someone will have the same problem, I got the gdb-12.cfg
> from the master and copied it inside the rtems-source-builder/rtems/config/tools
> directory. then I had to modify the rtems-default.bset file
> inside rtems-source-builder/rtems/config/5 by changing the gdb version to 12.1
> otherwise the builder will still use the 9.1 version.
> Thank you once again for your help.
Could you please raise a ticket for this and assign it to me?
The table at the top of this page https://devel.rtems.org/ has a link to help
create a but report for 5.4.
Thanks
