Error in building rtems 5.3 tools via mingw
Chris Johns
chrisj at rtems.org
Wed Mar 29 08:42:32 UTC 2023
On 29/3/2023 6:33 pm, Giovanni Righi wrote:
> I tried again with the flag --jobs=1 on a clean build and I got the same error
> message.
Thanks
> But this time it seems to happen on the second file. My idea is that with
> parallel building it managed to build more files before getting the error, while
> with only one job it's slower so it gets the error earlier.
Yeap but we now know which is the exact file that is broken. That is helpful.
I will add this to my list to take a look.
> Here's the tail of the log:
> ___________________________________________________________________________________
> + ./waf distclean configure --prefix=/c/opt/rtems/5.3
> 'distclean' finished successfully (0.000s)
> Setting top to :
> C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3
> Setting out to :
> C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build
> Version : 5.3 (5)
> Checking for program 'python' : C:/msys64/mingw64/bin/python.exe
> Checking for python version >= 2.6.6 : 3.10.10
> Checking for program 'python2' : C:\msys64\mingw64\bin/python2.exe
> Checking for program 'python3' : C:\msys64\mingw64\bin/python3.exe
> Checking for 'gcc' (C compiler) : C:\msys64\mingw64\bin/gcc.exe
> Checking for 'g++' (C++ compiler) : C:\msys64\mingw64\bin/g++.exe
> Checking for header alloca.h : not found
> Checking for header fcntl.h : yes
> Checking for header process.h : yes
> Checking for header stdlib.h : yes
> Checking for header string.h : yes
> Checking for header strings.h : yes
> Checking for header sys/file.h : yes
> Checking for header sys/stat.h : yes
> Checking for header sys/time.h : yes
> Checking for header sys/types.h : yes
> Checking for header sys/wait.h : not found
> Checking for header unistd.h : yes
> Checking for header vfork.h : not found
> Checking for getrusage : no
> Checking for program 'm4' : C:\msys64\usr\bin/m4.exe
> Checking for kill : no
> Checking for strnlen : yes
> Checking for fopen64 : no
> Checking for stat64 : yes
> Checking for library LLVM : not found
> Checking for header zlib.h : yes
> Checking for library z : yes
> Checking for library ws2_32 : yes
> Checking for compiler flags -std=c++14 : yes
> 'configure' finished successfully (12.090s)
> + ./waf
> Waf: Entering directory
> `C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build'
> [ 1/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_convert.m4
> Traceback (most recent call last):
> File "<string>", line 55, in <module>
> File "<string>", line 20, in run
> [ 2/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4
> OSError: [Errno 22] Invalid argument
> Waf: Leaving directory
> Build failed
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 181, in exec_command
> ret,out,err=Utils.run_process(cmd,kw,cargs)
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Utils.py", line 598, in run_process
> return run_prefork_process(cmd,kwargs,cargs)
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Utils.py", line 533, in run_prefork_process
> proc.stdin.write(obj)
> BrokenPipeError: [Errno 32] Broken pipe
> During handling of the above exception, another exception occurred:
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py", line 180, in process
> ret=self.run()
> File "<string>", line 14, in f
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py", line 173, in exec_command
> return self.generator.bld.exec_command(cmd,**kw)
> File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 183, in exec_command
> raise Errors.WafError('Execution failure: %s'%str(e),ex=e)
> waflib.Errors.WafError: Execution failure: [Errno 32] Broken pipe
> shell cmd failed: sh -ex
> /c/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/do-build
> error: building rt51
> Il giorno sab 25 mar 2023 alle ore 00:06 Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> ha scritto:
> On 23/3/2023 10:48 pm, Giovanni Righi wrote:
> > Ok so I tried what you suggested, I downloaded the rtems-tools-5.3 tar
> form the
> > server and I launched directly the waf script.
> > I got the same error, then I tried again and again I got the same error
> but on a
> > file following the one that caused the first error. So I launched the waf
> again
> > and it managed to compile all the files.
> > After this I did a waf clean and tried again and I got the same results,
> error -
> > error - compilation complete.
> > Note the two errors happened in the same files as the first "run".
> > So now I have the tools compiled but I don't know how to finish the build
> of the
> > toolchain, because if I launch the sb-set-builder again it cleans
> everything and
> > starts again so when it reaches the tools part it crashes again because of the
> > waf error.
> > I hope the explanation is clear and there is a solution for this problem.
> > I attach a file with parts of the three runs so you can see what's going on.
> Thanks. I wonder if the scripting used to handle the `.m4` files is broken on
> mingw? What happens if you add --jobs=1 to a clean build?
> What version of Windows?
> Chris
