Error in building rtems 5.3 tools via mingw
Giovanni Righi
righiqwe at gmail.com
Wed Mar 29 10:11:10 UTC 2023
Ok, also I forgot to say in the previous email that I'm using windows 11.
Il giorno mer 29 mar 2023 alle ore 10:42 Chris Johns <chrisj at rtems.org> ha
scritto:
> On 29/3/2023 6:33 pm, Giovanni Righi wrote:
> > I tried again with the flag --jobs=1 on a clean build and I got the same
> error
> > message.
> Thanks
> > But this time it seems to happen on the second file. My idea is that with
> > parallel building it managed to build more files before getting the
> error, while
> > with only one job it's slower so it gets the error earlier.
> Yeap but we now know which is the exact file that is broken. That is
> helpful.
> I will add this to my list to take a look.
> Chris
> > Here's the tail of the log:
> ___________________________________________________________________________________
> > + ./waf distclean configure --prefix=/c/opt/rtems/5.3
> > 'distclean' finished successfully (0.000s)
> > Setting top to :
> > C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3
> > Setting out to :
> C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build
> > Version : 5.3 (5)
> > Checking for program 'python' :
> C:/msys64/mingw64/bin/python.exe
> > Checking for python version >= 2.6.6 : 3.10.10
> > Checking for program 'python2' :
> C:\msys64\mingw64\bin/python2.exe
> > Checking for program 'python3' :
> C:\msys64\mingw64\bin/python3.exe
> > Checking for 'gcc' (C compiler) : C:\msys64\mingw64\bin/gcc.exe
> > Checking for 'g++' (C++ compiler) : C:\msys64\mingw64\bin/g++.exe
> > Checking for header alloca.h : not found
> > Checking for header fcntl.h : yes
> > Checking for header process.h : yes
> > Checking for header stdlib.h : yes
> > Checking for header string.h : yes
> > Checking for header strings.h : yes
> > Checking for header sys/file.h : yes
> > Checking for header sys/stat.h : yes
> > Checking for header sys/time.h : yes
> > Checking for header sys/types.h : yes
> > Checking for header sys/wait.h : not found
> > Checking for header unistd.h : yes
> > Checking for header vfork.h : not found
> > Checking for getrusage : no
> > Checking for program 'm4' : C:\msys64\usr\bin/m4.exe
> > Checking for kill : no
> > Checking for strnlen : yes
> > Checking for fopen64 : no
> > Checking for stat64 : yes
> > Checking for library LLVM : not found
> > Checking for header zlib.h : yes
> > Checking for library z : yes
> > Checking for library ws2_32 : yes
> > Checking for compiler flags -std=c++14 : yes
> > 'configure' finished successfully (12.090s)
> > + ./waf
> > Waf: Entering directory
> `C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build'
> > [ 1/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_convert.m4
> > Traceback (most recent call last):
> > File "<string>", line 55, in <module>
> > File "<string>", line 20, in run
> > [ 2/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4
> > OSError: [Errno 22] Invalid argument
> > Waf: Leaving directory
> > Build failed
> > File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
> line 181, in exec_command
> > ret,out,err=Utils.run_process(cmd,kw,cargs)
> > File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Utils.py",
> line 598, in run_process
> > return run_prefork_process(cmd,kwargs,cargs)
> > File
> line 533, in run_prefork_process
> > proc.stdin.write(obj)
> > BrokenPipeError: [Errno 32] Broken pipe
> > During handling of the above exception, another exception occurred:
> > File
> "C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py",
> line 180, in process
> > ret=self.run()
> > File "<string>", line 14, in f
> > File
> line 173, in exec_command
> > return self.generator.bld.exec_command(cmd,**kw)
> > File
> line 183, in exec_command
> > raise Errors.WafError('Execution failure: %s'%str(e),ex=e)
> > waflib.Errors.WafError: Execution failure: [Errno 32] Broken pipe
> > shell cmd failed: sh -ex
> > /c/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/do-build
> > error: building rt51
> > Il giorno sab 25 mar 2023 alle ore 00:06 Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> ha scritto:
> > On 23/3/2023 10:48 pm, Giovanni Righi wrote:
> > > Ok so I tried what you suggested, I downloaded the rtems-tools-5.3
> tar
> > form the
> > > server and I launched directly the waf script.
> > > I got the same error, then I tried again and again I got the same
> error
> > but on a
> > > file following the one that caused the first error. So I launched
> the waf
> > again
> > > and it managed to compile all the files.
> > > After this I did a waf clean and tried again and I got the same
> results,
> > error -
> > > error - compilation complete.
> > > Note the two errors happened in the same files as the first "run".
> > > So now I have the tools compiled but I don't know how to finish
> the build
> > of the
> > > toolchain, because if I launch the sb-set-builder again it cleans
> > everything and
> > > starts again so when it reaches the tools part it crashes again
> because of the
> > > waf error.
> > > I hope the explanation is clear and there is a solution for this
> problem.
> > > I attach a file with parts of the three runs so you can see
> what's going on.
> > Thanks. I wonder if the scripting used to handle the `.m4` files is
> broken on
> > mingw? What happens if you add --jobs=1 to a clean build?
> > What version of Windows?
> > Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20230329/bf9da22f/attachment-0001.htm>
