Anyone using Xiphos Q8 (Zynq UltraScale+ MPSoc)?
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 30 13:39:47 UTC 2023
I haven’t used the Q8 board, but I have tested the ZU3EG BSP on at least 3 different processor variants (including the dual-core CG variant) across about 5 boards and it has worked without issue. Be warned that u-boot doesn’t support elf64 (or didn’t last time I checked), so you’ll need to package it as a raw binary inside a u-boot image. This is the script I use to accomplish that:
$ cat create_image.sh
#!/bin/sh
aarch64-rtems6-objcopy -O binary "$1" rtems.bin
gzip -f rtems.bin
ENTRY=`aarch64-rtems6-nm $1 |grep \ _start|sed -e 's/ .*//'`
mkimage -A arm64 -O rtems -T kernel -C gzip -a 0x$ENTRY -e 0x$ENTRY -n "$(basename $1)" -d rtems.bin.gz rtems.img
I tend to load the image via TFTP for testing to avoid write cycles on the flash and for faster turnaround during development.
I suspect that the Q8 might have some system control and other interfaces exposed via the FPGA fabric similar to the CFC-400X, so that will need some extra work to support properly.
Let me know if you have any further questions.
Kinsey
From: users <users-bounces at rtems.org> On Behalf Of Schweikhardt, Jens (TSPCE6-TL5)
Sent: Thursday, March 30, 2023 4:03 AM
To: users at rtems.org
Subject: Anyone using Xiphos Q8 (Zynq UltraScale+ MPSoc)?
Hello, world
Is anyone using Xiphos’s Q8 boards? It features a Zynq UltraScale+ MPSoC and
out of the box comes with an SDK for Yocto Linux 2.5 (sumo).
I realize RTEMS has some support for a BSP using the Zynq UltraScale+.
I wonder what the challenges would be using RTEMS instead of Linux.
Is it more than replacing a Linux rootfs image with an RTEMS application image,
providing a device tree and booting via Xilinx’s uboot?
Regards,
Jens
________________________________
Tesat-Spacecom GmbH & Co. KG
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRA 270977
Persoenlich haftender Gesellschafter: Tesat-Spacecom Geschaeftsfuehrungs GmbH;
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRB 271658;
Geschaeftsfuehrung: Thomas Reinartz, Kerstin Basche, Ralph Schmid
[banner]
URL: <http://lists.rtems.org/pipermail/users/attachments/20230330/48935d86/attachment.htm>
